Anyone use cool gray sea deck yet?
Liveto99
New York Hudson Valley
I was thinking of using the cool gray on the swim platform and the floor of the cockpit? Nicer on the feet. I was looking for a pic to see if the 2 grays worked or looked like a frankinboat.
Grover70
Ponte Vedra, FL
FSH Deluxe
I believe this was called "cool gray" but I'm not 100% sure. If this is the shade you're referring to, it's the best investment I made on the boat. Quiets the ride, you don't slip, and I think it sharpens the look quite a bit.
Patae
Tallahassee ,fl
IMG_20180915_172758.jpg just installed it . Wife corrected me , ours is smoke gray over black.
Patae
Tallahassee ,fl
Bought a block of 1" seaboard and stainless bolts an inch longer that tha ones that came out. Cut it down , drilled the holes , Walla.
So to be clear, you raised the bench by inserting 1" blocks of starboard under the feet? You should post a new thread with this and some close up photos....and any specs you have (like the lengths of the new bolts).
18AR190
I went with the smoke gray over black. Mainly because the bottom of my boat is black but here are a few pics.
JoeSr
242 Limited E-Series
We have the sea deck on our 242Se in cool gray, looks great, we did the engine compartment less the two long strips on the tower side and the steps from the rear platform into the cockpit area. JBP does great work. Kim was very helpful when we spoke to them at JBP.
