Welcome to Jetboaters.net!
Going to Bimini our boats are heavily loaded. That weight increases fuel consumption but water conditions make an even bigger difference.
2017 was both my longest and highest fuel consumption crossing. From the mouth of Port Everglades to Bimini Sands was 4:20. I burned 38 gallons during that time leaving 14 in the tank. That is 1.6 mpg. On a good crossing to Bimini I would burn closer to 30 for 2 MPG. On the return crossing I typically burn around 25 gallons for 2.4 MPG.
First generation 240s burn more fuel than my 230 and the latest 240s burn even more. Several first generation 240s arrived in Bimini with a few gallons left in the tank while some new 240s needed a few extra gallons to get there.
My 242X burned 42 gallons on the trip there this year (1.42 mpg). We went a day earlier than the main group as the forecast was better. The X probably has the worst mileage of all the models due to the "bat wing" and the weight of all the extras (stereo and ballast). We also did not plane for much of the first half of the trip (roughest part) as I didn't want to damage my new boat!
My experience has been that riding in someones wake made the conditions worse. @Betik tried to ride my wake in 2017 I found it uncomfortable. Perhaps different conditions result in different outcomes.
I don't know. I was out on the lake a few weeks ago when suddenly the wind picked up quite a bit and it made for some rough conditions - for it being a lake. Probably 1.5' chop and some whitecaps.
It didnt bother us, but as we headed back towards the ramp, we passed a small aluminum johnboat, two adults and a (I guess) 3yo and a 1yo. No lifevests on the adults. I was surprised they were still afloat. As soon as i passed them they fell in behind me. I slowed down to match their speed, which got them out of the headwind and flattened the water for them. The woman in the front gave me a big smile and looked relieved. They stayed behind me and they made it safely to the ramp. Some people.....
@Berrie I did a lot of "practice" on my local lake with winds up to 20 mph ( at least 2 footers and speeds exceeding 40 mph). On top of that, I added sharp turns as if I was a drag dealer trying to outmaneuver the CG. It is with great humility that I have to report that none of that was even close to what I faced crossing the gulfstream. If you have access to salt water please do spend some time there.
@Betik I don't have much saltwater experience but I do have a crossing behind me already (2 if you count each way), and the weather was far from good. Last 10 miles was solid 3' @ 3 seconds, strong winds with whitecaps everywhere. I never felt we were in danger or near the limits of the boat, and we stayed completely dry, but it wasn't pleasant.
One thing i learned: store your stuff at the lowest point of the cabin as everything will end up there anyway....
@Betik I guess that's the advantage of a cabin cruiser. A high bow, eisinglass, and we stayed dry - even in the rain.
The disadvantage is needing 3' of water, and towing restrictions.
@Bruce That was early in the day. About 1.5' - 2' at 6 seconds. It's a little rougher than it looks. Note that the whole 12klbs is almost out of the water.
@ Bruce That was early in the day. About 1.5' - 2' at 6 seconds. It's a little rougher than it looks. Note that the whole 12klbs is almost out of the water.
Lol that was the first thing I noticed. It looks like a smooth day but when I saw how far the bow was out of the water I started to think he was either hauling tail of it was a little bigger then it looks. Having had a similar size boat years ago I know it's a heavy son of a gun.
I saw a boat doing that this past trip. Getting almost completely airborne... I thought he wanted to take the lead as he was passing me.
Not too long after he discovered a substantial crack in his hull.
@tim h As long as the waves are relatively low it won't slam you into the next wave. Once the waves get higher and after every wave you slam into the next, you'll eventually break something.
