Engine bay platform
Tranquility Base
I have monkey arms but they’re not long enough to reach all the way to the back of the engine bay! There’s no where to support yourself when you boom out to get to the oil filters or intermediate bearings.
I bought a 2X8 and some 3&1/2” deck screws and threw this together today. This gives you some place to put your hands and a place to lay your body when you’re reaching into the engine bay, and your not putting weight onto the coil packs and injectors…. @drewkaree @WiskyDan @Ericd @Can0n11 @Dixemon
Dimensions;
32&1/2” cross board
7&1/2” drops
2&1/2” top tabs
Great idea. On my boat, its the latch piece that digs into me when I try to lay across to do any work.
Frickin' Genius! You literally solved one of my biggest gripes.
I had been thinking about this wayyyy too long and should have acted on it sooner.. but better late than never. I may put some moving blanket material or dense foam on the top and sides just to take the sting out of whacking an elbow on the edges.. I suppose one could get creative and put some tool holder holes in the board to make doing those chores in the back of engines easier still. The main thing I needed this for was to get to the intermediate shaft bearings to grease them.
At first I drilled a hole big enough for the deck screws to just pass right through the first piece of wood to keep the wood from splitting, and I drilled a smaller pilot hole into the second piece of wood, again to keep it from splitting. But! I used the self drilling type of deck screws and found that I didn’t need to drill those holes at all… when I got the two drops attached they were off so it rocked a bit, and I knew that if I put the tabs or hangers on they would not sit flat, when I went to re position the outside screws is when I noticed that the deck screws were self drilling so I just lined things up and screwed them in with my drill and no issues.
I used just a 2x8 and towels to keep from scratching the top. I will definitely have to give this a go because a 2x8 wanted to slide around.
I was using a sheet of plywood before but it held me up too far from what I wanted to get to….
I like it..............hate using 5 or 6 folded towels on engine tops after removing Yamaha coil cover .............and always making sure not to put hands or weight on the plastic fuel injector rails!!!!!!!!
Where did you get those red hose clamp ends on your deck drain hose? I have many war wounds from those stupid things. I finally just wrapped with electrical tape which looks like shit.
I responded yesterday to this thread using my phone..didn’t notice there was just the tiny amazon link so here’s a couple screen shots. Like you, I had left many blood stains in the engine bay from working around the hose clamps, I saw these protectors in some boat tests on the high end CC boats.
This actually looks like the best bargain.
I also found these to go over the exposed end of all the wood screws. These are available from 2-14mm.
Swap over to T-style hose clamps
I built mine a few years ago then didn't know where to store it...it ended up under the boat/trailer which was just the ticket.
Dimensions;
32&1/2” cross board
7&1/2” drops
2&1/2” top tabs
I just made a similar one with two strips of 3/4 plywood glued with 3 bond and screwed together( already there from another project) and used oak 2x2 as the bench rest up top and the hinge point for the platform....I like your design better but mine was free material wise with what was on hand....... using it to get to the back while replacing the intermediate bearings.... Nice to not be laying on top of the engines worrying about breaking a coil or a connector while wrenching away. Thanks for the helpful idea.
