swatski
- North Caldwell, NJ
EDIT: FANGS are a new upgrade to the Ultimate Cobras, here is the description:
https://jetboaters.net/threads/cobra-venom-fangs-now-available.8915/
Well, I installed and tested the new FANGS today. In a word: awesome.
Ordering and delivery - I had the item at my door exactly two days after I paid an invoice for paypal transaction. Shipping is included.
Install - its pretty easy, albeit I have the newest Cobra Ultimates I think already pre-drilled for the FANGS. I found the last two pictures in the install manual to be the most informative.
Basically, I took the "lateral stabilizer" plate/brace off, it is held by one bolt, and I installed the FANGS like the pics. Sorry - not the best quality, but it really is not difficult. Keep in mind - pictured here is a single engine/pump assembly.
(EDIT: Please note the LOCKING TABS need to be installed last - ON TOP of the crease in the steering nozzle - please read about it further down in the thread)
The Ultimates - before FANGS install:
The stabilizer brace taken off the bottom of the venturi nozzle - with its bolt/bushing/washers:
The bottom of the venturi where the brace/plate attaches:
PORT side FANGS assembly - note the shorter bolt on top:
PORT side assembled, STARBOARD ready:
Both FANGS assembled onto the brace and ready to be mounted (note the bolts' head/nylock nut orientation):
Bottom view of the FANGS/brace mounted back onto the venturi nozzle:
Assembly completed - port side and rear views:
Performance notes - what can I say, already great system taken to the next level. No surprises here as far as the "power steering"effect - works exactly as advertised. As far as the reverse - it becomes laser sharp with the FANGS. I actually surprised myself here, didn't think much of it at all as I got busy at the dock, and just noticed my backing up maneuvering being very sharp.
So - a 100% recommendation from me. I really like riding with the fins down at speed, and this should be good for the cables, primary handling benefits notwithstanding.
Here is how Jeff describes it, I think it says it best:
The upgrade is for people who want a power steering effect and even more reverse control, they are for the Ultimate and Magnum steering systems to allow you to run the steering all the way down all the time with power assist to reduce the resistance in the helm , these special fins basically turn the nozzles for you at speed, plus they help confine the reverse thrust when it exits the opening on the bottom of the nozzle, it's just an option to make a great system even better for people who think they would benefit from the added features.
