FLJetBoater
- 242 Limited S E-Series
So...got the new (to me) boat out on the water today. 2014 242 Limited S.
First the good - this boat is incredible. We were only on inland lakes today so there wasn't much chop but even over the other boats wakes was no problem. Towing, cruising, everything was just so much fun. Engines started up 20+ times while we picked up tubers and wakeboarders. You hardly even feel the tubers back there with the twin engines. I installed Cobra Super Ultimate fins yesterday and I could not feel any pull from the tube or wakeboards when they were out to the side. AND, I remembered the clean out plugs and the drain plug.
Next, the embarrassing. Guess who was ready to sink the boat before we even left the dock? This guy was...because it wouldn't start. Engines cranking, cranking, voltage alarms, (but I knew the batteries were good, I charged them last night) but no starting. 5 minutes pass....looking at engines, batteries, turn on emerg parallel just in case. Nothing. Realizing I'm "that guy" at the ramp whose boat doesn't work, blocking everyone else. Finally it strikes me....the kill switch lanyard wasn't plugged in. Got that installed and off we go engines fired right up! Loading the boat back on the ramp also falls in this category. I put the trailer way too far back in the water so the bow was coming in under the roller. We finally got it right but it took a really long time. For you guys who trailer, how far do you put your bunks in the water? After looking around it seems that 2/3 is the right answer. I was easily past 100%. Also, do you drive your boat right up to the bow roller? Would there be a risk of sucking anything up into the jets as the water would be quite shallow at that point.
Lastly, the bad. Steering was very tight especially at high speed. I replaced the reverse cables yesterday, one was rusted right through. I have the steering ones here but haven't done them yet. I'm hoping that's all it is. Maybe a job for after work this week. I also noticed a pretty rough idle, exactly like what was mentioned here https://jetboaters.net/threads/new-boat-new-member-engine-rough-idle.26664/ in those first videos. I'm hoping all it needs is some Seafoam - going to try that tomorrow. I did put in 32 gallons of gas before we went out so the tank was getting empty but no idea what the qualify of those other 18 gallons was.
Don't know if anyone has wakeboarders in their group, but my girls (12 and 18) and another friend (20) were having a really tough time getting up. Not sure if it was the driver, but I was the common denominator. Any tips for how to accelerate? slow then fast, steady, etc? Or is it just getting a feel for it.
Back home now....having a cold one and thinking about my next trip out.
