Drexx3
- 242 Limited S E-Series
I've read in several posts here that the cabin speakers on my boat (2020 242 SE) are likely still wired in series as Zone 1 on the Fusion head unit and the two speakers on the swim platform are alone in Zone 2. I have the Wet Sounds OEM amp in front of the help and am considering either replacing it (to my wife's dismay) or adding a separate small amp just for the sub and use the 3 zones on the WS amp to separately run the three pairs of speakers.
A few questions...for those of you that have changed the speakers from being in series to in parallel, did you have to run all new speaker wire or were you able to somehow take advantage of wiring already there? Not sure how but thought I'd ask.
With the OEM Wet Sounds amp being closed off of setting adjustments, would it be possible to achieve the 3 zones I'm looking to do? I also haven't pulled the Fusion unit in the back to see if I have RCA plugs or need the new adapter. Again my wife is boggled by I'm considering spending $1000 to replace equipment already on the boat that is already supposed to be 'upgraded'.
