For those looking for an SVHO intercooler...
REM835
Lebanon, OH
SX192
I went ahead and picked one up also. Money well spent if they end up working out. I'll post up pics when it arrives.
Matt J
Springboro OH
Chaparral
Geez!! where was this deal a few weeks ago:eek: Can't beat the price, and cheap shipping to. Really happy though that the guys here that want to make the change are able to do it rather cheaply.....
haknslash
Lake Martin, AL
Moomba
Looks like we'll have a lot of happier 192 owners here soon :)
Corey Champlin
SX192
Thinking about buying this since it is such a good deal. Wanted to know for sure, will this fit my 2013 SX 192 or do I need something different.
haknslash
Lake Martin, AL
Moomba
Same engine
REM835
Lebanon, OH
SX192
The eBay order came in the mail today. Looks fine I think. The fins inside have a little surface rust but it looks to be just from sitting. The photos make it look worse than it really does actually because of the light I was using.
IMG_0975.JPG IMG_0976.JPG IMG_0977.JPG IMG_0978.JPG IMG_0979.JPG IMG_0980.JPG IMG_0981.JPG IMG_0982.JPG
Buckeye Boater
IMG_6620.JPG Just got mine and both discharge points are busted off! Not happy.
Buckeye Boater
Seller is on vacation till the 19th....
I recall someone had one of the hose barbs break and they tapped it and added a brass fitting. Seems like it would be easy enough, the question is would it be ok having brass threaded into plastic? anything special that would have to be done to make the union watertight?
haknslash
Lake Martin, AL
Moomba
Mine is the one you're talking about with the brass fitting. The guy I bought mine from had his break on him during shipment when he bought the SVHO intercooler, so he just tapped in a fitting. Honestly you're life would be much easier if you tapped in two 90° elbows as opposed to straight ones. It would give you much more room for your hoses. I kind of wished my other one was broke so I could tap in two 90° fittings. I'd use NPT pipe fittings.
Buckeye Boater
Hey Hacknslash, do you know the diameter of the threaded part for those fittings?
haknslash
Lake Martin, AL
Moomba
I never took it out to measure but you could measure the inside diameter of your ports and that will give you an idea of the thread size you need.
Big Shasta
Panama City Beach, FL
I did something similar to a fuel fitting that broke on my Yamaha warrior 1700 motorcycle. It worked find for the next few years before I sold it. I used waterweld 2 part epoxy putty on and around the threads to hold it in and seal it up.
Andrew Doherty
PWC
Just to clear up the eBay listing, they are brand new 0 minutes on them with 0 corrosion. They are listed as used because they were installed at the Yamaha factory. The hoses are cut off because we don't reuse them. Riva builds race skis and special Riva limited editions for customers and we remove these to install our much larger intercooler.
Sorry buckeye boater for the shipping damage on the one I sent you. I will get a new cover sent out to you or I can send you the brass fittings for repair whatever you want. I have 90 or straight brass. I will be back at work on Wednesday and will contact you then.
Shannon
Holly Springs,NC
AR192
This is awesome! I ordered one on Saturday and can't wait to get it installed! Thanks for the post Andrew!!!
Shannon
Jetswu87
Brass fittings in those photos look like 3/8 or 1/2 NPT. Should be widely available at any hardware store in the plumbing section, teflon tape or paste the threads.
However if they are willing to send you a replacement top that'd be more ideal in my opinion!
Buckeye Boater
Appreciate the info Andrew. I would like a new top if you can make that happen.
Shannon
Holly Springs,NC
AR192
Andrew just got delivery from UPS and have a broken tip on the intercooler..I contacted UPS and they said to contact you 1st..below are pics.. Please advise..
