Here’s the data sheet for the NGK 6955 plugs that go into the TR-1 engines. Notice that the manufacturing gap is .032”, the Yamaha service manual state’s minimum gap at .028” max gap is .031”. The service manual also states if the gap is out of spec to replace the plug. I’m going to read that as, set the gap at .028” and if the gap has grown beyond .031” replace the plug. Spark plug installation torque is 9.6 ft lbs. The service manual also states to be sure and not let any water or debris fall into the open spark plug hole, then goes on to say to clean the spark plug gasket surface, I’d like to see how that’s done without getting debris into the spark plug hole. I do usually give several blasts of compressed air into the spark plug well after removing the coil pack and before removing the plug.
Here‘s the box the set of four plugs came in. Thanks for pointing out the good deal
@drewkaree! They do look like the real McCoy based on very close inspection.
Note the install torque for aluminum heads at 7.2-8.7 ft lbs, OR hand tight + 1/2 turn. Notice also the second sentence of the first line below the tightening chart, “ always refer to your owners manual and gap to manufacturer specifications“.
And just to eliminate all confusion [sic] on the individual spark plug box it shows the tightening method of hand tight + 1/4 turn. Way back when, I remember being taught that a spark plug that has this type of sealing surface / gasket which is a crush washer, that tightening by a fractional amount of turns was the proper way to tighten them.
Here is a pic of a brand new plug and it’s crush washer.
And a pic of a plug with 73 hours on it. You can see the crush washer is crushed. Also notice two threads of heat..I’d like to see three, but it is a boat engine, and the threads are pristine. I did not put anti seize on these threads before installation.
Here is a pic of the plugs that came out this season with probably a bit over a hundred hours, and I put anti seize on it.
I’m a pragmatic not a dogmatic, so based on observed conditions,
@drewkaree ’s comments and the fact I boat in fresh water I‘m going to have to seriously reconsider putting anti seize on the next set of plugs, at least one set to see what happens. I do think if I was boating in saltwater I would put a very thin coat of anti seize on the plugs and would tighten the plugs between a 1/4 & 1/2 turn (splitting the NGK packaging instructions baby) per the NGK directions, dissimilar metals is bad, toss in salt water and it’s very bad. My intention will be to check the amount of turn when I torque the plugs as well, my recollection is slightly less than a 1/2 turn.
Also, be sure and use a good wire type feeler gauge when checking plug gaps, it should be a snug fit as you pull the wire through. That’s an old school one I’ve had for decades…
Epilogue; I have to wonder if these cases of seized spark plugs is the result of over tightening, in
@lazergeek case I think it was the factory installed plugs, toss in a little salt water and the plug becomes one with the head. Does over tightening remove the non corrosion coating ? And why was it only one (think goodness it was only one) plug that seized ? If it was a case of corrosion shouldn’t there have been more that were seized? There’s also something to be said for possible corrosion on the treads that are exposed in the combustion chamber and those threads possibly corroding and those corroded threads making extraction impossible?
