Gunnel flush mounted rod holders
Tailwaters
St Joseph MI
Looking to install a couple Scotty flush mounted rod holders about even with the helm. However I'm not too sure how strong the tops of the gunnel are? Looking underneath they appear to just be screwed to the sides of the boat liner. Anyone else make such an install?
The lovely Mrs. Highanddry wanted nothing to do with me posting photos of her sleeping on the bow so...IMG_20170906_110600330_HDR.jpg IMG_20170906_110719293.jpg
So yes, they work quite well.
Perfect that's what I wanted to see. Sounds like there must be enough substance to that piece to bolt to. I'm looking to install the flush mount holders that way I can remove them when not needed.flushmount-1000x1000.jpg
After further review looks like that's what you have :)..
Yep. Drill the large hole to match perfectly so that there's no extra play. Bed it in a little 4200. Don't over torque the 4 screws. The screws I used bit and held fine but you could always thru-bolt with a washer and lock nut for extra piece of mind.
I think @OUT ON THE REEF did a video on this....but it might just have been a grill mount....but similar process.
How thick is the top? I'm planning on running some small dipsey divers for fall salmon. I may run a backer plate as well.
I mounted my triple racks on the gunnels. Admittedly, I need to redo it at some point, to 'beef it up'. I just drilled (3) holes, and bolted everything up. Good idea on using 4200 adhesive as well. I was surprised how thin the fiberglass was, and was hoping there was metal sandwiched in there, but there's nothing. I'd be hesitant on running downriggers without some stronger backing under the gunnel.
I have a bunch of Scotty Holders in my garage, from my kayak, that I could use, but I wasn't a fan of the white boat with black holders. I do like the idea of your white flush mounted holders.gunnel.jpg fishing.jpg
I won't be installing in downriggers. Just was concerned as to how strong the top plate was being it appears to be just a bolt on piece. Last thing I want is to see stress cracks in that area.
I guess it was strong enough that I wasn't too concerned mounting my rod holders. But I would like to beef it up over the Winter. I'll let you know if they hold if I hook into a Green Bay Musky this Fall! ;)
This is not me, or my fish, but....it's what I'm trying to catch:
i added a track system and put 3 tubes per side. I havent noticed any issues with cracks or movement in over year. Not uncommon to troll two or three rods per side out of these.
Ended up mounting two on the top of the gunnel just about even with the middle of the helm. That way I can see them while trolling plus they are in front of the bimini top while its in the down position. Marine store only had Atwood holders in stock that were flush mounted. They looked on par with the Scottys and Cannon brand. I did like the fact that they had a clam shell style cover that was made of rubber that covered the entire base plate while not in use.
Are the tower rod holders able to fit any size tower tube? I want to order those.
As an alternative to drilling into your gunnel, I found these on Amazon. $40-50. Adjustable.
That's a nice idea. I'm concerned with the integrity of the existing rod holders. I plan on fishing off Cali for tuna this summer, and I don't want to find out my rod holders can't handle it.
Lee's Summit! I'm right down the road from you in Pleasant Hill. I think that I saw your boat at Surdyke not too long ago...
Probably did. Mine sat in their lot for 3 months.
I know the feeling. They had mine for over 2 months, assured me that it was covered the entire time, and when I went to pick it up it had 6 inches of water in it and looked like a tree was growing out of the bow.
