Neutron
- New Bern, NC
I havent seen it this high in the 3 years i have been here. And we have a ways to go
True! Been there done that!Just don’t stick the strap or rope through any slots or holes in that shaft if you like your arm. Also don’t wrap too much length.
Is your dock under water already here?
Just heard someone died from plugging in their generator. Early news so dont know specifics.For those wiring up a generator.
-SHUT OFF THE MAIN to your house
- Go BIG on the cord
- Wear leather gloves, eye protection, and rubber soles when pluging it in or flipping breakers.
- Shut down while fueling
- Do not run it in a garage or under living space even with the door open.
Common sense stuff but in a pinch some take chances .... its not worth it.
My custom cord (door knob for size reference)
There have been 4 deaths reported so far according to my Weather channel news feed. The guy plugging in his generator was one of them. Ya'll stay safe.Just heard someone died from plugging in their generator. Early news so dont know specifics.
That is awful. I don’t know the cause but obviously all connections to any household wiring should be done by a licensed electrician. Grounding is super important. Some setups require a seperate chassis ground on the generator. In my case I went with 14-50 nema connectors 6/2- 8/2 RV wire and confirmed that my box was properly earth grounded suppling the box earth ground to the earth ground prong and that my generator chassis was connected to the earth ground prong on the other end. Wearing a welding mask, welding gloves, and rubber soled hiking boots may sound excessive for plugging in a geneator but that is what I do even with my robust wiring and a ground prong that is longer than the others (ever notice that ground prongs are just a tad longer than the others on male 120/240 plugs? This is for a reason.Just heard someone died from plugging in their generator. Early news so dont know specifics.
I hope to heck you are kidding??I chop off the ground plug with wire cutters. I rarely even shutoff the power to swap outlets and switches. Maybe i should be more careful! To me the ground is just a redundant common. It's only there for that remote chance that the common wire is cut while you are exposed to a bare wire. Besides the wire color, they are interchangeable to the main panel (but not a subpanel)
We dont ground when we tailgate and hook it up to the trailer to power TV ectQuestion....using a freestanding generator and plugging extension cords into it (IE not connecting to the house wiring), is it still recommended to ground the generator? If so to what?
