Tailwaters
- St Joseph MI
- FSH Sport
One of my old offshore boats with above water exhaust had the flappers burned out. Came in one day during a storm and when we got back to the dock a wake hit the back of the boat an in the water went. Next day I hit the key to hear a god awful noise. Sure as neck hydrolocked the motor and bent a rod. However that's not always the case. Every once in a while you can get lucky by pulling the plugs, spray some oil in the cylinders, change engine oil and turn her over by hand a few times. Turning over by hand will allow you feel any sort of hang up or resistance. Worked at a marina when I was younger so ran into this problem a time or two. Of course I'm in fresh water so that certainly helps pending how the water was ingested.
