Welcome to Jetboaters.net!
ISLAND JAY has your Jetboaters.net Clothing, hats, stickers and more all at a 30% discount until June.
Click Here for more information>SWAG for JetBoaters.net members only
I like to take my son (almost 2) out to the marina on weekends to look at the boats while we wait for ours. Hope to catch a glimpse of this beauty. Congratulations again.
Connelly Pilot water ski does fit nicely under the starboard side front seat going back into under the helm! WOOT It also will fit on the wake board racks....which are so heavy duty and sturdy....they rock! I love the easy swing in aspect!
@Jet Blue She'll be on B dock soon on an Airdock....
The colors do work really well! I'll be taking lots of pics this weekend...and need to get the forum stickers on too...once I have that complete, then I'll get a new signature image up! Trust me....that is on the list!
Man look at that hooligan jet skier why must they get so close to the boats when riding I hope you pulled out the water cannon and soaked them for getting that close. They should learn some respect.
I think we put 7 hours on the engines today...and that was with a false start in the morning! So we are working out a probem with rockin' stereo on the boat...there is a short somewhere. Dealer said I could delay picking it up, or bring it in later to figure it out. So there was NO WAY I was going to wait any longer, so I took the boat with the stereo "partially working". Well, partially working, is more than just a problem for the stereo....as it turns out that partially working also means....shorting and draining the batteries....BOTH of them somehow. (or at least that was what I thought...forgetting the bad readings on the Connext)
So I arrive at the ramp, back the boat in, undo the straps, and get in the boat. Turn both start and house batteries to ON, and you get the long beep, only the beep never stopped.....I have a Drive Control -Check engine alarm. Push the buttons to start and nothing. See the battery voltages and they both read 11.7.....my heart sinks.....
So I go back and flip the emergency combined switch hoping that Yamaha for sure hasn't fixed the battery voltage indicators....and presto, the engines will start. I smile and think... ok...lets do some boating!!!!
Put the engines into reverse and nothing....no movement....no reving...no control at all. Still have the Drive control - check engine error. So I call the dealer and Yamaha. And get the same answer from both of them. Shut everything down, Switch to combine first, then turn on house, then start and see if error clears. IT DOES!
So this takes what seems like an hour, and was probably only 15-20 minutes....but it was the longest 15-20 minutes in my life! Thank you Chatlee Marine and Yamaha Tech guys!
So now I need some coaching on how to find a short that could drain a battery. I have what I think is a decent voltage meter....but it is probably one of the items I am most clueless on how to operate! So treat me nice....and lets see if I can find the problem....
I chased a problem with the Sirius draining the battery once. I found it easiest to disconnect all negative wires from battery. Leave positive hooked up. Set your multi-meter to read DC current and clamp the black lead to the battery negative post. Using the red lead, probe the black wires that went to the battery. The one that is drawing current while the keys are in the off position will tell you where to start your investigation. Once you found it you will have to go device to device to ID the bad guy. You can sometimes accomplish this by opening breakers. Other times you have to unplug the device. Having paper and pencil on hand will help.
