captainhook
- Southern Maryland
- Limited
Yes digging down is what I did at both houses for the Intex pools. I also put sand under them as well. They will still shift some but blocks under the legs helps. Make sure the blocks don’t have sharp edges and are a bit larger than the “feet” as the legs will flex out as water is put in. Definitely plan in some space outside of the pool where you dig the circle larger than it so you have some room to work and aren’t trying to trim grass right up against the pool vinyl.
