Replacing the trim on our "storage closet" door opening
itsdgm
I finally got tired of having sticky glue exposed and gaps in the corners of the door due to the original factory trim shrinking. So I decided to replace it. I know that other guys have done this mod already, but I didn't see it posted on Jetboaters.net yet. Also, thanks to Julian for providing me the correct item number to order.
I started by ordering self gripping plastic edge trim with metal core 9/64"-1/4"opening 21/32" H, White 10' length, item # 8451A61... from McMaster-Carr It cost $11 plus shipping.
Here's what I used to complete the task.
1. Replacement door trim
2. Goo Gone
3. Cloth Rag
3. Something to cut the door trim
First I started by removing the old trim. It was glued on, so there's a very sticky mess left behind.
Next, I used Goo Gone to remove the glue with a cloth rag. Don't use paper towels, they will stick to the glue.
Once the glue was cleaned up I simply pushed on the new trim. I started and ended on the hinge side to keep the seam out of the way. Also, expecting that this trim will probably shrink a bit, I made every attempt to push on as much as possible. When I cut the end, I added at least 1/3" extra which worked itself out as I pushed it on.
The trim has a metal banding inside that helps hold it in place. Here's the hose cutter that I used to cut it with.
Here are a few pics of the finished look.
maboat
Lake Ray Hubbard, TX
:thumbsup:
I did this a few years ago, and highly recommended for anybody who hasn't done it yet.
Detonate
Colleyville, TX
Tige
Would this be the same part number for a 2005 model boat?
I removed the gluey mess a loooooong time ago, but never replaced the trim.
maboat
@Detonate Yes, that's the same part I used and would be the same for your boat. I also enlarged the opening while I was at it. The newer boats look like they already have a larger opening, but on the older boats, there was room to make the cutout bigger. I made my opening just slightly smaller than the size of the door itself
Lspeedss
Powhatan,VA. 23139
Nice job. I thought I was the only one with that problem..obviously not..lol​
KXCam22
Kamloops BC
I need to do that. My trim has shrunk. Where did you get the trim? Cam.
itsdgm
I ordered self gripping plastic edge trim with metal core 9/64"-1/4"opening 21/32" H, White 10' length, item # 8451A61... from McMaster-Carr It cost $11 plus shipping.
  • Like
Reactions: Gym
maboat
PEARCE
Kaufman, TX
I dealt with the sticky goo last season by removing the original trim and all the glue and reglued the original piece. I kept getting the goo on my arms or on our stuff and I finally figured it out where it was coming from and took care of it.
Jim Robeson
Springfield, Missouri
I used a little fast cure 3M marine on mine...worked like a champ! After I cleaned up the other gorilla glue...that stuff was nasty!!
Dennis does not mess around! He asked me for the part number on Sunday, get it on Tuesday and has the job finished by Wed! My trim has been in my garage since last August! Putting me to shame! (as I sit in a hotel room hundreds of miles from my house)
itsdgm
It would've taken me days just to research the part number. Thanks again for the help Julian.
justason
SWAG Forum Lead
This is great ! thanks Dennis, Julian. I need to do this as well. Been taking a back seat to fighting with the seal around my engine hatch..
Caught my eye, the part number above isn't directly on the web page, but appears to be the same as 8451A13
itsdgm
Honestly, I never looked at the catalogue. I just called them (on a Sunday even) and gave them the item number. It shipped on Monday, arrived Tuesday and installed on Wednesday. Apparently I live within a few miles of where McMaster-Carr is located.
ratchetdu
Las vegas 89148
SR
I like this. Saw it before on other site, but haven't done it yet... Just ordered this piece. The lady saw it and said, "Why haven't we done this. I'll even scrub the sticky stuff off if you get this!" I may hold her to that...
ToddW850
Destin, Florida
That's the ticket right there. I'll be doing this. Thanks @itsdgm
after taking the old trim and glue off last year I never got around to ordering the part to fix it. After seeing this thread and link for the part # I thought how could I pass up such and easy fix. It really was, ordered Friday, arrived today, had a few hours of daylight when I got home and took about 20 minutes to push it on. I wondered how secure the fit will be and it worked great. I also did the door frame on the helm compartment. I will have to trim a little bit of the carpet that had glue on it but otherwise GREAT!
THANKS GUYS!
itsdgm
THANKS GUYS!
I know. I was putting this one off just because it seemed impossible for me to research which exact trim to order. But @Julian set me up with the part number and supplier. The rest was a piece of cake.
justason
SWAG Forum Lead
Thanks all ! I placed my order this morning.....oddly I never saw a shipping cost. blind faith ?
related: Has anyone replaced the seal around the engine compartment hatch ? That piece is driving me nuts !!
ratchetdu
Las vegas 89148
SR
Didn't see a shipping cost for mine either, and was a bit concerned. Got the confirmation receipt this morning, and shipping was about $6. And is out for delivery. Ordered Sunday afternoon... :)
