- Raleigh, NC 27614
- 242X E-Series
Thanks for posting this !!I found that disconnecting the scupper hose at the cabin end and allowing the whole thing to but assembled outside the boat was a lot easier that trying to reach down to push it together....not sure if everyone else did this....then all I had to do was slide on the hose clamp and tighten it.
@Julian how did you put on the large threaded nut that came with the scupper valve? Did it slide over the drain hose?I found that disconnecting the scupper hose at the cabin end and allowing the whole thing to but assembled outside the boat was a lot easier that trying to reach down to push it together....not sure if everyone else did this....then all I had to do was slide on the hose clamp and tighten it.
Nice. That's thinking out of the box err... out of the bilge.I put it all together in the bilge...that was when I realized it was going to be a bear to push the hose onto the barb end of the scupper. So I disconnected the cabin end and slide the scupper and hose out. I just slid the hose clamp and threaded nut up the hose further. See the shot below....this was before I got smart.
Is this the correct Life Calk that you guys are using?
That's what I used. I found it a little more user friendly than the 4200 as the set up time was a little slower.Is this the correct Life Calk that you guys are using?
Why didn't you just put your name on the scupper wrench list? We have 2 or 3 floating around that we all just ship between each other.Great. I ordered the new scupper over the winter. Just ordered that plumping wrench another member suggested. Found a new one on ebay for $8 plus a little shipping, so the Life Calk is the last thing to get.
Thanks everyone!.
Ordered mine I need to get on the scupper wrench list!
