Neutron
- New Bern, NC
I sure will.. but it should read fine because the starboard is 1/2 inch thick and adapter bracket makes it another 5/8 to 3/4 lower and it makes it protrude below the hull as per lowrance instructions. As you can see from straight down the hull it is below just as it shouldNice install. Would you mind posting a follow up if you loose readings at speed? Mine is installed there, but with a thinner material. I loose bottom at 30mph. Not a big deal, but curious.
