Towing
viper15
Wisconsin
I used to tow with the poles in because I was too lazy to pull the cover off to take the poles down. I figure the discussions of poles in or out is mostly for that reason, guessing most leaving poles in were like me. But then I remembered that the good mooring cover has the zip-open pockets over the cleats. All you need to do is open those pockets, take the straps off the cleats at all four corners, then give a few straps a tug. The poles will fall down. Then tuck the straps back in the boat through the pockets. I just leave the poles lay in the boat until I get to my destination. Easy peasy.
Speedling
Cedar Lake, IN
SS
Seadeals
Greenville, South Carolina
DITTOOOOOOOOOOOOOOOOOOOOOOOOOO LOL. One thing fun about towing poles out is when you do get into a torrential downpour all you have to do is tap the brakes and a wall of water will come rushing out of the bow cleaning the tailgate that the car wash couldn’t seem to get.
AZ Native
Phoenix, Arizona 85044
I found out the hard way that towing with the poles up on my last Yamaha (2005 AR230) put too much strain on the straps and they both broke at the bow. I'm in the habit of removing the cover before towing 45 minutes to the lake. I have a 5 hour tow coming up in May to Lake Powell (house boating), I will remove the poles and tow with the cover on. But I'm going to try the Beach Ball trick. Makes perfect sense.
Mainah
Chapin, SC
If anyone decides to move the axels as opposed to the bow stop be sure you know what you are doing. Getting the axles perfectly square and aligned is a must do to prevent a blow out. Also one of those things where a little move will have a big impact. The bow stop move while perhaps not the best method is certainly the preferred method of the common end user without acess to the proper alignment tools and just as effective.
I still don’t understand why the tounge weight is so far off from the factory on what seems to be all the models. Perhaps it has something to do with shipping but this is a safety concern and should be rectified somehow.
adrianp89
Tampa Bay, FL
252SE
I wonder if the dealer would adjust this under warranty.
I doubt it. I would bet it has something to do with Yamaha legal exposure, knowing how they operate...
For example, some of the boats are factory equipped with ballast bags. That is a huge "cluster" as far as legal exposure - even in the water as the boat weight capacity must be severely stretched to accommodate (different story). But as far as towing - a partially filled (not fully emptied) ballast in the rear of the boat could, conceivably, tip the balance and lead to a catastrophic failure.
EDIT: And then, all the other boats (without factory ballast) - leak enough water into the bilge, it could still tip the trailer, lol.
(joke)
I generally tow with the tower up. Catches lots of insects, so we do keep cleaner handy.
I take painters tape and put it on all the forward facing edges of the tower when towing long distances. Makes bug removal much easier! Just yank off the tape. Takes 10 min to put on max.
Daren Humphries
Chattanooga, TN
I like that idea! I also use Topcoat F11. Although very skeptical at first I am really happy with the results. Makes cleaning so easy.
Of course I use the blue painters tape to match the blue color of the boat! LOL (I really do...and my daughter asked if that was why I was using blue....it was just what I had in the garage!)
Daren Humphries
Chattanooga, TN
I'll be doing the same on our drive down to FL in June and will tell my 2 boys the same!
Daren Humphries
Chattanooga, TN
Would anyone on this thread know what these parts are for. We got them with the 212X and I can't figure out what they are for. The rubber pads are stick on and the brackets look like they may be something to do with the Wetsounds speaker bar.
AZ Native
Darn, I like this idea, but I’ve never seen Black painters tape.
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
You are correct sir!
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
Great. Thanks very much. Do I need them? Everything seems to be factory fitted fine. Would they be required for another application maybe?
I know my boat uses the long black brackets so I am kind of curious how they mounted them on the 212X tower. So if you don't plan on doing anything with them pitch them. I would keep them because i am a hoarder. :confused:
