drewkaree
- Central WI
I've already posted this before, but I'm breaking this out on its own to make it hopefully easier to find, and not get lost in the threads for those who search. I'm also doing it to create one place for the included files, for anyone to 3D print replacements for the little white caps that cover the springs for the Twist Lock style cleanout plugs. This was all done after @KingCold had an issue with some missing parts, linked here but thanks to his measurements, this turned out to be the push needed to solve the problem of replacing the white caps that you'll see later on down in this thread. I'm also adding the original files from that thread. Those files simply give options to those who wish to look at the original design, and test them for yourself. I've noted the older file that's attached - I recommend the other one, but I'd like options, so I'm including them for others here too
The zip files attached here have the following files: 3mf, STL, STEP and F3D files
For those of you who have a 3D printer, you should know what those files are, and should be able to use any of those to print new parts in case you lose the white spring caps for this style of plug. If you don't even see those springs, follow along with this thread to see where they're supposed to go, as well as some measurements of the parts that should be there. I have no idea where to get these parts other than Amazon, and you're going to have to do some of the heavy lifting to find those parts yourself. These SHOULD fit every Yamaha that has this style of cleanout plug - they haven't changed the design as of the date of this thread.
For those who want a non-toxic lube for the rubber gaskets on your cleanout plugs, Click here for a link to make your own safe-around-the-kids cleanout plug seal lube.
While you're looking at this whole area, possibly due to trying to track down some water entering the boat (or a whole lot of water in the bilge), it may be making it past the cleanout plug rubber seals. This may be an assembly flaw, or just very loose tolerances of the parts, and the manhole rebuild kits may not be the actual problem you're having, so just in case your actual problem ISN'T the cleanout plugs and seals for them, click this link here for an all-time winner that was sussed out by @TeeNGee to add o-rings to this area. Follow through the thread for more info regarding that discovery.
Anyway, on with the show
