Yamaha Diagnostic System (YDS)...how to read your hours and errors
jetboater4life
Rochester, MN 55901
Can someone post a picture of a screenshot of the YDIS software that shows an error code? I could not find any error codes, but maybe I wasn't looking in the right place. I'm trying to track down why my port engine occasionally dies at idle, even after a plug change.
If you look at the file I attached on post #1 you can see the diagnosis section has one record. If you grab the file via YDS and Save AS CSV - that is the exact result. (my error is an over heat that happened when I was on Lake Minocqua trying to get to Tomahawk Lake and took a wrong turn and ended up in the weeds!)
serg of energy
Columbus Ohio
Near Columbus Ohio - does anyone have the cable and software that I could borrow? I would like to get an hours reading before installing a meter.
jetboater4life
Rochester, MN 55901
Thanks @Julian . I kind of expected to see it at that point in my file but only see
Diagnosis Record,
,Total hours of operation,109.4,
,Code,Item,Occurred,
,,Diagnosis Record is unavailable.,
I guess this means I have not had a code on it since I purchased it with 47 hours in Sept 2012. My intermittent die at idle and my port no wake mode flakyness aren't showing up. I'll try the no-wake mode fix next spring, and hopefully yet another plug change will remedy the die at idle. I did test my fuel injectors with the YDS and they all seemed to be fine.
Here are my files. In cvs format.
jetboater4life
Rochester, MN 55901
Is the idle speed just set too low, or does it run fine then struggle and die?
That is something I can look into but I haven't noticed a difference from the starboard. It may be related to the no-wake as well. It doesn't happen on every outing. When it happens it's usually idling to pick up a skiier or bring the rope to someone in the water.
jlcj7
Tega Cay, SC
MikeyL
Passed Away
In Memoriam-RIP
Lake Oconee, GA (Greensboro)
jlcj7
Tega Cay, SC
Perfect!
Is one of these the correct plug that it plugs into?
txav8r
Lake Ray Roberts, Texas
I don't believe so @jlcj7 . All of the previous boats had the connector behind the starboard round inspection panel in the engine compartment. I haven't looked on my newer 240, but I assumed they were still behind that cover. They are marked for each engine. Again, I may be wrong but they didn't used to be out I the open.
jlcj7
Tega Cay, SC
ok, i will have to look for it in person... If anyone happens to have a pic of the general location i would appreciate it... In the meantime, since this appears to be the correct cable and software, i will get it on order
Murf'n'surf
Naples Florida
jlcj7
Tega Cay, SC
Ok thanks... I re-read Julian's first post a bit closer and he did mention that it could be in that location for the 210s.
So i unplug at plug and plug in the YDS cable, correct?
What is that random loose plug in my picture that is hanging off by a zip tie/fishing string? (below my yellow circle)
Murf'n'surf
Naples Florida
That is the plug to keep water/debris out during the time when the plugs are not mated. IE engine swap or manufacturing.
mark_m
Columbus, OH
Has anyone tried to get the software running on Linux? I have a laptop with mint, which I think is a Debian variant and main pc is an iMac.
Thanks
Mark
kthrash
Madison, MS
I have the YDS and laptop in Central Mississippi if anyone needs to use it.
tdonoughue
The Woodlands, TX 77381
jlcj7
Tega Cay, SC
Just read my hours. I am at 73.4 hours on one and 73.5 on other.
PORT ENGINE:
5.Data Logger [Engine operating hours according to engine speed]
Engine speed Time[h]
- 2000 r/min 29.08
2000 - 4000 r/min 4.27
4000 - 6000 r/min 11.91
6000 - 8000 r/min 28.24
8000 - 10000 r/min 0.01
10000 - 12000 r/min 0
Total hours of operation 73.5
STARBOARD ENGINE:
Data Logger[Engine operating hours according to engine speed]
- 2000 r/min 29.11
2000 - 4000 r/min 4.25
4000 - 6000 r/min 12.18
6000 - 8000 r/min 27.52
8000 - 10000 r/min 0.43
Engine hours 73.4
Apparently i idle around more than anything else... Also interesting that my starboard engine seems to get over 8000 RPMs more than my port engine. throttles must not be set perfectly, but close.
I bought the boat new in December 2011, so used during seasons in 2012, 2013 and 2014 so far, so i guess i am averaging 24.5 hours per year...
Spectre170
YDS 1.33 & Windows 8 confirmed to work on 2012 242 L/S.
I bought the cable and software from eBay from the seller that was linked earlier in this thread. I checked my engines today with the YDS software and had no issues with it at all. Followed the instructions in the first post and everything worked great!!
I took a couple pics and put some instructions on them to show the exact cables to use in the boat and how to disconnect them. I figured it out from previous posts but it took me a few minutes to get it. Thought this might make it easier for someone else in the future. Giving back to the community that has definitely saved me countless hours and $$!! Also anyone in SE Michigan that needs the cable & software let me know and you can borrow mine.
2012 242 YDS diag cable loc.jpg 2012 242 LS YDS diag cable harness.jpg 2012 242 LS YDS diag cable 3 wire.jpg 2012 242 LS YDS diag cable 3 wire tab.jpg
