biffdotorg
- Pelican Rapids, MN
- Limited S
Doesn't look like there's anything on the tops of those wings that would make them non-slip, if they were intended to be steps.
Do you think they might be on a track and slide back and forth?
I don't see a transom ski hook mount, and it doesn't look like you can hook a tow rope to the top of the tower. Even if it is a big boat for cruising, I would still think you want a way to hook up a tube and drag the kids around the lake.
That might explain the cutout in the hardtop - rope attachment underneath?
Looks like it would be more for clearance for the walk-through.That might explain the cutout in the hardtop - rope attachment underneath?
It looks like it slides on a track to go all the way back maybe.and another...
If you look at the rear seatbacks, you can see the metal brackets that will allow the backrest to swing to the rear. The picture has it in its forward position.
In the original pdf photo the rear seat backs are in the rear position, just in front of the fuel fillIt looks like it slides on a track to go all the way back maybe.
Actually pontoons are much lighter than fiberglass boats.And a pontoon is pretty heavy.
