anmut
- 212S
Thanks - did you call them directly to order these or find them on the website or other source?
I did not, have not tried yet, I was just trying to help out as initially I did not realize that I had to scroll down to find #350 O ring.Thanks - did you call them directly to order these or find them on the website or other source?
Well I'll let you know when I get them. $12.50 a piece + $14 in shipping, just FYI!!I did not, have not tried yet, I was just trying to help out as initially I did not realize that I had to scroll down to find #350 O ring.
How many are in a pack?I bought them here: Pardon Our Interruption
I bought 5 packs of #248, #350, & #425 for $23.81 shipped.
I may try stacking a pair of #248 and see how they work.
Thank you!I bought 1 pack of each size with each pack containing 5 rings.
I believe the o-ring is sealing between the groove in the port and the bottom of the lip on the plug. It may also cause the rubber skirt on the plug to bulge slightly and seal against the wall of the port.I'm trying to understand what the O-ring is doing in the equation. Is it sealing the bottom of the rubber ring on the cleanout plug, or is it giving the rubber ring something to slide over, and giving structure to the bottom of the plug?
If it works, and can be slid up into the gap between the rubber skirt of the cleanout plug, and by eliminating any flex there, that's the bit it needs to seal, then maybe other things can be slid into that gap as well.
Sounds like a great find!
I think having an O ring there will tighten up the fit and increase the sealing pressure and cause the “skirt” to flex outward in the well to provide a better seal, which by your account it totally does. Very exciting.I believe the o-ring is sealing between the groove in the port and the bottom of the lip on the plug. It may also cause the rubber skirt on the plug to bulge slightly and seal against the wall of the port.
I think putting something into the gap between the rubber skirt and the cleanout plug will cause the skirt to rub as the plug is installed.
Thanks.I think having an O ring there will tighten up the fit and increase the sealing pressure and cause the “skirt” to flex outward in the well to provide a better seal, which by your account it totally does. Very exciting.
I was trying to figure out a way last year to tighten up the fit between the top of the locking groove to add downward pressure on the seal but realized that wouldn’t work because it’s a groove and would be limited in travel so to speak, so you’re idea with the O ring is brilliant!
LOL! Either way.. the nut was found and it was a good one!Thanks.
It's a case of blind squirrel finding nuts.
Thanks to TeenGee - I ordered some O rings directly from their website. 1 was the same price as 46 so I have 45 extra! Put in the O ring and did a plug rebuild. Seems to fit nice and snug now.
Last time out, my plug was filled with water and the inspection lid was forced open. I’m hoping that was the major source of my leak and hoping this will fix it!
You can adjust the latch arm by loosening the allen head set screw and turn the latch arm down to tighten it up, don’t forget to tighten the set screw back.Nothing else was back there and not sure what it is supposed to feel like. It is a little looser than I would expect, so I will try to figure something out to make it more snug. I had already added weather stripping around it as I don’t want to spend 100+ on a riser
the plug was completely full of water
the inspection panel had been opened up
