Another Clean-Out Plug Thread
There's still the issue of backwash up the drains, but it's not nearly the frequency or severity, and I'd bet that's where residual water would come from if the tray is sealed and the hatch isn't leaking.
Agree with this. However, it's incredible how much water was being pushed past the plugs and into the boat. Come on Yamaha, do better.
I think the concern for most as well as myself is "why" is there water on top of the clean-out plug. I just took out my 2024 255xd and only have water on top of the Starboard Clean Out Plug. Is the cavitation is hear at times due to the plug not staying sealed and water passing by the plug? I like the design mindset behind the Clean Out Plug concept but am concerned with performance and durability if the Jet Pump Pressure is too much for these plugs.
I plan on putting a GoPro inside the compartment next trip out to get conclusive evidence of the origination of the water. I will post what I find.
So I sold 2 Yamaha FX jet skiis in order to have a family boat. The skiis had no clean out.. and I NEVER had any issue with cavitation.. while I like the idea of a clean out port, i believe the clean out port Is the cause of at least some acceleration cavitation... the following is my reasoning so let me know if you agree.. the impeller that pulls water( a serious suction of sorts) is aft of the clean out port.. with the power of the suction( not pressure as mentioned above) any possible breach of a solid water pull ( ie air drawn past the clean out port) would cause cavitation(slipping clutch) effect.. this is why if you back off the throttle (impeller suction) the impeller will grab water and accelerate.. therefor it seems to me that the port MUST be sealed of any possible vacuum leak in order to prevent cavitation issues on acceleration.. the fact that water gets past the clean out indicates it is not sealed.. And i agree the water above the clean out does not come from over the stern wash, its forced past the clean out.. in addition if you do have water above the clean out and you accelerate(assuming the clean out not sealed) the impeller will now draw down the water above the clean out, not air, therefor no cavitation until that amount of water above the clean out is gone.. Slow the boat down put pressure into the area if the clean out and now you get water back above the clean out.. I’m no engineer but have a good amount of common sense and i believe Yamaha had a good idea with the clean out but had poor execution.. After all these years they should have had a permenant fix… Not temporary bees wax.. shame on Yamaha
Testers are needed, here's hoping for more reports of success.
I picked up some o-rings from MSC. Will see how they work for me and note it here. After doing the plug/gasket repair kit (F3F-67609-09-00) and the JBP riser the other year, I don't get any water in the bilge, but if I can keep water out of the tubes, even better! :)
Anyone try the o-rings on the old style plugs? The non-screw-in type?
Some measurements might be needed for others as well, so if someone does try this, be sure to help everyone else and throw up the details. Measurements, what was used, where it was from, thicknesses and whatnot.
Except that there videos out there showing the clean out tubes with water flowing out of them while accelerating and underway.
The clean outs and the ability to clear what I’ll call soft clogs are what sold me on buying a jet boat, without those no way am I jumping in the water to clear weeds or a plastic bag.
Keeping the seals and the plugs in good working order, and keeping the areas where the seals rest in the tubes clean is a maintenance item.
Beyond clean out seals that are bad and or have dirty sealing surfaces, cavitation is caused by a severe pressure differential, vacuum on the impeller blades leading edge, Cavitation - Wikipedia
just like in science class where you put a cup of water in a vacuum chamber. Sir Charles Parsons discovered this with his ship the Turbinia which was the first steam turbine powered ship Turbinia - Wikipedia So, even when the clean out seals are good hammering the throttles at a standstill can produce cavitation that is unavoidable.
I received some O rings from @Spooky pantz and gave them a test fit yesterday…
When I installed the clean out plugs, it was reminiscent of how the installing process felt when my boat was new, firm downward pressure was required to be able to twist the locking handle. (Just replacing the seals with new ones made no difference). Looking forward to testing them next week!
