- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
@Betik , text me a pic of the brown plastic parts...I might be missing some attachment to the toilet
Seriously, I might recognize them.
Yeah, that "winterization" term really doesn't apply and it is only ancestor worship to do all the heroics that some guys continue on these boats. So you are not only "winterized", but you did pretty much the exact same procedure you will always do when you pull out of the water...with the exception of fogging, which if you remember, I said needed to be twice a season on fresh water, and MUCH more often on salt water. Contrary to some belief too, your not going to dissipate the fogging oil by again using the boat. So really, your ready to go right now, and you won't hurt it to use it during the winter, and no need to refog the engines again until sometime in the spring! Just keep the tank topped off without overfilling (filling in winter and then having it expand in the spring on a hot day can ruin your graphics on the side of the boat), always blow out the engines/exhaust, lube linkages 3 or 4 times a year, annual or hourly maintenance...your good to go!
