meegwell
- Central Virginia
- 242X E-Series
Hi all,
I have an ongoing issue that I believe I can't resolve even with the wonderful help and knowledge of everyone here. I am aware of everywhere in the manual that it is addressed and it simply does not make sense or does not work the way it says it should. The issue is serious enough that I need to resolve it. I bought my boat second hand at a non-Yamaha dealer out-of-state (not many choices this summer!!!) so I don't have the option to go back to the dealer. I am thinking I should start emailing the issue to Yamaha dealers and hopefully have some luck? I believe I've read that contacting Yamaha directly will not work. This is my primary question for this message...what is the next step for help?
Another thing I want to be sure of is that I am stating the issue clearly. This issue has been beat to death here and I have been part of that beating at least in the past few months (it has years of history). I think I've read every message here related to it at least twice. Because of the different configurations in different model years they are not all relevant, but I've covered them all and have posted many question...and received many good suggestions. I will state my issue below let me know if I can do a better job of explaining it before I take it to Yamaha or dealers or whoever next.
2018 242X e-series boat (no manual flip buttons at helm, all electronic buttons and connext, push starts for engines, single key on the side)
1. The boat stays wet and uncovered at the marina for the summer months.
2. The bilge pump operates perfectly fine so long as the boat power is turned on (key in on position, batteries on, engines irrelevant), draining water automatically as needed.
3. The bilge pump will not operate/drain water, no mater how much is in the bilge and engine compartment, if the boat KEY is not turned on (even with batteries on).
4. This creates a hazard if I do not put the mooring cover on and we get heavy rain. I have experienced this (engine compartment filling up) both by natural situations (unexpected rain storm while boat docked and not covered) and testing (using a hose).
5. I have done extensive trial/error testing with a hose: before turning the key off, leaving the bilge button with blue/green/blue and green on. I have always left the batteries on.
Obviously the bilge pump works. Obviously I can take the boat out of the water, travel somewhere and have a second bilge put in. I can also somehow wire the bilge pump directly to the battery I believe...but...Shouldn't I be able to lock (remove the key) my boat at the marina and not worry about a rain storm filling up my engine compartment????
Any input appreciated.
