2kwik4u
- Buffalo, NY
Changed the oil and the plugs in my '17 AR190 Saturday. Everything went as it should. No surprises or issues. Pulled 3.5qts of oil. Refilled to between the two holes on the dipstick.
3yr old was in teh boat "helping dad" and was messing with the key at one point. So I had the lanyard off, and in my pocket to make sure he couldn't accidently crank the boat while I was working on it. In hindsight I realize it still cranks, but won't fire with the lanyard off. I'll take the keys next time.
Went to restart, and FORGOT I had the lanyard off, so it took a few tries before I put the lanyard back on and it of course fired right up, but had a SHRILL constant tone from the gauges. I have a check engine light now. The alarm was almost instant after firing back up. Water flow was good, oil level looks good. I shut it off immediately, and rechecked everything. It was running smooth and started quickly and easily. I refired it, alarm still there. Seems to be running just fine. Again, nice and smooth, quick and easy startup. Oil level looks good, water flow looks good. Voltage on the gauge was reading 14.2V or so (which seems about right for this boat). There's not much else on this to check really.
NOW, if I just bump the motor to get the gauges to come on, I continue to have a check engine warning and constant tone. Even with the engine NOT running. Like the code is stored and is now on all the time regardless of engine running.
I ran the engine for ~15min ahead of time on last years oil and plugs to get it warm before servicing. No issues there, everything was fine. Battery has been on a tender all year, and checked good at like 12.5V or something just touching the posts with a meter.
How the heck can I clear this code to see if it comes back, and how do I read it without YDS? Hate to buy a $400 tool, just to read a single code. Don't really want to drag it to the dealership to have the code cleared either (although that is certainly less expensive than the YDS setup). Any thoughts from resident gurus?
