E-Series Ribbon Delete
props2you
Round Lake, IL.
Seems to be @swatski is the resident Ribbon Delete aficionado, I divert some questions...
Has anyone done the delete on the E-Series? Started to dive into it but seems a bit more complicated and than other models. Yamaha has put everything inline on the E-Series (see pics) and reduced the amount of room to remove parts. Can't even take the airbox off unless I get a wrench on the backside of the bolt in the fuel tank compartment. (the nut on the airbox just spins and spins) I realize 2 bolt on and 2 slide in the rubber grommet, but it's a PIA to get the 2 undone.
Seems like a lot of work for 200 RPM...
Any tips or suggestions??
Rod5
Marietta GA
255XD
Totally worth it! 200 RPM on top but 15% more mid range and throttle response especially noticable on heavy loads or pulling tubes.
No need to loosen those bolts - the airbox pops off the rubber grommets, snaps right back on.
The E has the same setup/parts as non-E.
I'm no longer a Yamaha fanboy, but here are some pics - always happy to help a fellow jetboater!
And - yes - totally worth taking this choker out, whether or not you put the RIVA rings.
And while on it, I would also rip those snorkels out of the airboxes for another 50 RPM or so. Make the engines sound a bit throatier, but not bad. No need to change the filter, IMO.
Nauticajetter
Fruit Heights, Utah
I did it on an e series. @swatski is right about just loosen the hoses an slide the air boxes out. Don't lose the gaskets and make sure they go back on correctly. It was a great mod especially if your higher elevation. The hardest part was removing the snorkels on the air box. Just pull hard and they come off. I also added the new air filters to be stay USCG approved. Holler if you need any other info or run into any problems. It's simple except my ribbons were really tight so I had to drive a screw into tnto pull it out.
Matt Phillips
Lake Tahoe
I'm still torn on this one.
Do you run without the Riva sleeves and just let the air swirl around in there?
blacksapphirez
Charleston, SC
SX195
yes. i run consistently 7700~7750 rpmsno problem
the rings "may" help the air flow and may help in acceleration in various RPM range but high end limit is same with or without it
captras
Lake Livingston, Texas
Interesting thought but a couple of questions.
I am not that interested in3-4 MPH top end but does it affect efficiency at all? To somebody who is not a performance geek, is this worth the trouble?
I am assuming, if you had engine problems, Yamaha would say your warranty was voided by this......ideas?
Thanks
Nauticajetter
Fruit Heights, Utah
I also went without the sleeves. If you can slide the ribbons out without using the screw method you could always just throw them back in for warranty if you are paranoid. As far as if it is worth it.. you are near sea level so I really am not sure if the juice will be worth the squeeze to you.
props2you
Round Lake, IL.
Thanks @swatski I can certainly understand your loss of trust with Yamaha after your Bimini trip, and their response.
I'm a fan of the procedure just ran into a few hiccups and needed clarity. My airboxed looked as if one side was bolted on and the other had the ability to slide off. I'll give it another go later this week. Thanks!
scokill
Rowlett, TX
I am not that interested in3-4 MPG top end but does it affect efficiency at all? To somebody who is not a performance geek, is this worth the trouble?
Thanks
I'm assuming you meant 3-4 MPH, which is well within the range of impacts of wind, load, water conditions, etc. I would say no from a pragmatic standpoint.
Nick Hughes
Columbus, OH
FYI: I did the ribbon delete with RIVA sleeves. And while I was getting a max of 7000 RPMs before at my lake, 1600 ft above elevation. I still only get 7350 and a max speed of 43 MPH. Thats on a dead smooth lake with cooler temperatures, 65 degrees. That was Sunday. Full tank of gas, 2 adults, 2 small kids. I feel like Im missing some RPMs and MPH somewhere, but no idea where. The last 10% of my throttle doesnt increase anything.
Your signature suggests that your boat is in the water all the time? If so, there is your power drain! A dirty boat adds drag. Before I got my lift, my boat would sit in the water all the time. After a few months my top speed (SX230) would drop from 49 to 35 :eek:. Then I'd pull the boat out of the water, clean all the scum off of it, pop it back in...and voila...back up to 49mph! Reproducible every time. Here in NC my boat would grow a furry algae on it pretty quickly. Up north in IL/WI this wouldn't happen. The boat would collect dirt/grime up north, and slow it down a little, but nothing like the warm southern waters.
The ribbon you are deleting is a spark arrestor. If I were to do this, I would follow Nautica's lead and be sure to add back spark arresting filters. I'd also consider the cheap insurance of a fume detector (something I think all boats should have standard)
Nick Hughes
Columbus, OH
IMG_0530.JPG My boat is actually on a lift, hull is buttery slick.
props2you
Round Lake, IL.
@Nick Hughes Sidebar... How do you like the Cobra AK Magnums with the fangs?
@Julian Have you done the ribbon delete? If so, noticeable difference? Coming from a 2010 242 Limited I feel the 242 LSE is a bit soft on the power. Maybe it's the heavy bimini top/cage and overall added weight. Full tank, 4 adults 4 kids, drinks food etc. I was only getting 7k 7100 RPM and 43 mph. Was a bit disappointed, compared to my 2010, understanding the previous weight mentions though.
Then something is amiss. My 242X has a max speed of 45, but I attribute that to boat loads of stuff in the boat (pardon the pun), and the "Bat Wing" drag. That said, I rarely go full speed as the wife and kids complain its too windy!
Nick Hughes
Columbus, OH
I wouldn't be backing my boat into my slip without fins/fangs. They also help tracking down my 10 min no wake zone and not having to constantly over compensate the steering.
F.M.
Decatur, AL
255XD
For those that have gone the ribbon delete route. What flame arrester filter did you use for the mod? I have found the R&D part #200-01800. Are there any other options?
The truth is you don't really need one in fuel injected (not carburated) engines, this is an antiquated USCG rule that we (sometimes) follow. If you do - there are many ways to do it. I have switched to using stainless cones which are considered as flame arresters.
Post #22
https://jetboaters.net/threads/wakesurfing-ballast-on-swim-deck-air-intake-issue.16254/page-2
