Bill D
- Prairieville, LA
- Limited S
Your assumption is correct. And trust vectoring and rudder effects are not mutually exclusive.I think it is interesting that these do not work in the way we would expect them to. They come up as soon as you push the throttles forward (they are tied to the buckets). Most people assumption (mine included) of the fins working like rudders in incorrect. The fins really elongate the jets .
They don't though. Go to their home page and watch the gif in the lower right corner. They come up when you put the throttle forward. Completely kills the no-wake and idle forward use cases. You really only get reverse assist from these and then thrust vectoring.Your assumption is correct. And trust vectoring and rudder effects are not mutually exclusive.
The Ultimates certainly do work like rudders at speed. When installed in a manner that makes them stay down at speed. That is the whole point, really.
On the other hand, the "new" knockoff hydro-whatever work EXACTLY THE SAME as the older Cobras and all TVs, they gradually come up at speed, be that by being pulled by the gate or being forced up by the jet stream pushing an actuator.
@Julian I have to say you have me pretty confused. Maybe it is the same as with the fangs, where there was some initial confusion about what do they look like...Cobra fins and thrust vectors both work the same way this new fin works with one exception.
In reverse they are identical, they:
In forward cobra fins and thrust vectors only act as a rudder because the jet output (thrust vectoring) doesn't benefit from two fins on each side of it. This is why these fins have gotten larger and larger over time....to increase the surface area of the rudder. This new model has no, or limited rudder effect when the buckets are in the forward position, and having side "braces" to the jet output seems pointless to me as there is nothing in the way of the thrust from the jet like there is in reverse.
- direct the flow of water from the jet output
- use their surface area like a rudder
Perhaps I'm missing something, but these look like they will only solve half the problem and are more expensive.....but I'm happy to be proven wrong....lets see some real world turning video!
That would be correct only if you lift the gate all the way up in one instant, which is usually not the case. At slow speeds and in no-wake mode the gate is partially lowered and so are the hydrojet fins.They don't though. Go to their home page and watch the gif in the lower right corner. They come up when you put the throttle forward. Completely kills the no-wake and idle forward use cases. You really only get reverse assist from these and then thrust vectoring.
This is my 2010 242 LS with the throttles forward to the first detent like you would have them set for no wake areas or leaving the dock.That would be correct only if you lift the gate all the way up in one instant, which is usually not the case. At slow speeds and in no-wake mode the gate is partially lowered and so are the hydrojet fins.
But even with the gate fully up, you still have these little "ears" hanging down just enough to have some influence (perhaps), as in the gif.
Different means of lifting the fins, but it is the same concept.
That looks like the gate is fully up in your picture. Not sure how would the 'no-wake" mode work with a gate fully up/open?This is my 2010 242 LS with the throttles forward to the first detent like you would have them set for no wake areas or leaving the dock.
This.Not an arguement at all....a discussion of the mechanics.
The gates on our boat move to the forward or the reverse position BEFORE any throttle is applied. So if you are in any level of no wake mode, the gate is fully open. The TVs and Cobras allow you to have the fins below the pump while running forward in no wake mode. This new design does not. Thats all I'm pointing out. So they will only work in reverse.
I always thought the TDE and the no-wake mode operated using partial forward or reverse shift/reverse gate positioning, in addition to operating throttle/RPM. But if the gate goes all the way up BEFORE throttle opens up/RPM rise, than I had it wrong.This.
