Sorry also forgot this is only good for thirty days so get them to post date the letter to your planned trip time frame. Which they should do no issues.
Dear Sir:
Re: Authorization to fly in Bahamas Airspace
This letter is authorization to fly UAV Registration ***********, DJI Phantom 3, Serial Number
**************, in Bahamas airspace under the following conditions:
(1) The person in charge of a small unmanned surveillance aircraft must not fly the aircraft in any of the circumstance described in paragraph (2), except in accordance with a permission issued by the Bahamas Department of Civil Aviation.
(2) The circumstance referred to in paragraph (1) are-
(a) Within 5 nautical miles of any airport;
(b) At a height less than 200 ft;
(c) Over or within 150 meters of any congested or populated area;
(d) Over or within 150 meters of an organized open-air assembly of more than 100 persons
(e) Within 50 meters of any vessel, vehicle or structure which is not under the control of the person in charge of the aerial vehicle, without special permission of the Owner;
(f) Within 50 meters of any person;
(g) Subject to (c) and (d), during takeoff or landing, a small unmanned surveillance aircraft must not be flown within 30 meters of any person;
(h) Paragraphs (d) and (f) does not apply to the person in charge of the small unmanned
surveillance aircraft, or a person under the control of the person in charge of the aircraft;
(i) A small unmanned aircraft means a small unmanned aircraft less than 15kg in weight used for personal recreation and for which any images or data collected (if so equipped) are not
commercial gain.
(3) This validation shall remain valid for a period not to exceed Thirty [30] days from the date of issuance unless sooner removed, revoked or surrendered.
N. B. The Department of Civil Aviation will not be responsible for any accidents, incidents,
mishaps, damages or injuries that may occurs as a result of the operation of Unmanned &
Remotely Controlled Aircraft, and will require that the operator/owner assume all such
liability.
