- Raleigh, NC 27614
- 242X E-Series
Going to copy that! Do you have a wider shot? Looks low....but might just be me....
I like it....fills in the sound gap in the 242X cabin. It came with the boat....so I didn't install it.@Julian how do you like the Wet Sounds bar? I've been looking into this...I have 2 8" Icons on there right now and debating on putting two more on there or go with a bar. We mainly listen at the cove/beach and don't need projected sound, but want to be able to hear it good (better!) while swimming and hanging outside of the boat. The bar would eliminate another amp, so that is a big plus. Did you install? If so, how was the install?
Gotcha! My fenders live in one of the stern storage lockers.I spaced it so I could still get the table in, but would still have room for my fenders
What Font is that?Hydrotherapy 3 actually (a cool new font for the cool new boat).....the SX230 was 2, and when I added the stern speakers it covered up the 2, so I took it off. Although I did briefly consider Veedubteksspareboatwheneverhewantstouseit, but couldn't afford the full boat wrap we'd have to have bought to fit it on the boat!
This was from Doityourselflettering and is called "Borg 9" with italics and a drop shadow.What Font is that?
I never put anything wet inside storage compartments like that. If it is damp...maybe....but typically any wet jackets go on our porch to dry before going back on the boat.New owner and boater here so sorry if this is a stupid question, but if you hang your life jackets in the starboard storage area, is there any concern about your electronics getting wet or damp? Or is that only dry storage for the jackets and when wet you keep them somewhere else?
What size screws did you use to mount shelf? I read it but I may have missed the size
How did you attach that paper towel roller to the handle?Here is where I put the paper towel holder. I thought the handle WAS a paper towel holder. So I attached to it....the handle is solid (not hollow) so this worked well.
The towel holder is designed to screw on to things....and I learned the the handle is solid, so I just screwed it right on, and its been perfect! The only tricky part was sliding the hangar onto the bracket...you have to bend it slightly to get it on....but that is a one time event. Of course I pre-drilled the holes.How did you attach that paper towel roller to the handle?
Do you have the measurements of that rod? I'm stealing that idea too! Also, did you add those metal brackets holding the rod or those where there?Here is where I put the clothes Rod. I bought a nice chrome one, but was worried it might rattle, so I went with wood instead.
This was a total home depot special. I got chrome rod holders for closets and a closet bar I had sitting in the garage....I went with wood because it is at an angle and I didn't want metal rattling....and frankly...wood was much quicker to cut and deal with!Do you have the measurements of that rod? I'm stealing that idea too! Also, did you add those metal brackets holding the rod or those where there?
