- Panama City, Fl
- Other
Well, it will be interesting to compare the Yamaha "drive control" with the Ridesteady in action. But I can tell you right now, the Ridesteady turn/push-knob (optical reader?) is GENIUS. I would pick the knob control over going through Connext menus every time. That KNOB is just super handy.
(Same with PP Stargazer screen w/arrows for that matter, not the most easy to adjust on the fly)
Well, the E-series boats with Drive Control are certainly very nice, no doubt about it and, at any rate a direct comparison w/Ridesteady is kind of moot as E-series do not actually use APS (accelerator position sensors).The E-Series launch controls/speed control is super easy too....especially when using the touch screen. Also, once you set your 5 preset configurations for Launch speed/target speed/ballast amount, it is a one button push to set the boat up for each rider....can't be easier than that! Except my wife sometimes forgets to press the one button! LOL Which is interesting for about 15 seconds....then I let go!
EDIT: After I read it, I need to modify this post -- sorry if I came way too strong, really didn't mean to!
@Julian Thanks for responding.
This day and age I would consider a real CRUISE CONTROL function as A GIVEN in any sports boat.
Yamaha only offers a "cruise assist" that is not a real cruise control, including in their top of the line $$$ E-models. That cruise assist only works between 3,000 and 7,000 RPM which is way under 40mph in some conditions, and is limited to +/- 7 or so 200 RPM steps.
And that's all I'm going to say.
I do like the idea of OEM Drive Control for water sports, it can do fun things. But, no matter how much one likes it that thing is NOT a replacement for a real marine "cruise control". There is no way you would want to use “Drive control” for regular cruising, as you need to be able to hold speed OR rpm depending on conditions and what you are doing.I don't think you are too strong in your reply! I learn so much from these discussions....it is the point of the forum!
I'd argue that the E-Series boats do have a very exact cruise control that does even better than a car. Here why I'd say its better:
The UI could be better....but because it will do the ramp take off, they didn't want to make it too simple for liability reasons (love it when attorney's mess up our fun!). I agree that since they have a GPS controlled speed control....why didn't they make Cruise Assist operate from it...but my guess is the majority of users are perfectly fine with a fixed rpm based cruise control (not wake sports control) in increments of 200 rpm.
- It will automatically take the boat from a stop to your designated cruise speed
- It accomplishes #1 in 3 ramp up speed choices . Some cars with adaptive cruise will now let you go from your cruise speed down to zero and back up again, but not the other way around. However, there is no choice in its return ramp (my Dad's car is a little agrressive)
- It will lock you into speeds down to the 1/2 MPH - no cruise I've seen on a car will do that!
I guess we both have different needs. Regarding your points above:
- Works only from 8 to 40mph (more than enough for wakeboarding, but many cruise above those speeds)
- It locks into a set speed
- In the X-models, it requires ballast to be completely filled or drained before it activates
- Car comparisons are not very useful, boats cruise best at constant RPM for best fuel economy, especially in chop/bad weather
Excellent points, @Julian. But I think it is important to not loose track of one pertinent idea in this discussion: Connext models including 242X E-series do not offer "Cruise Control".I guess we both have different needs. Regarding your points above:
Love my wake sports cruise control....and will on occasion use it for simple cruising too. But in reality, if it is flatish water, setting the throttles works fine for me. If it isn't flat water, I want control and wouldn't use cruise control. So I guess we'll just have to agree to disagree on the shortcomings of RPM based cruise assist. Would GPS be a little nicer...sure....but to the average boater....not a biggie. I'm sure Yamaha will add the sorts of things you seek as the model years increase.....they have been behind in the wake sports "specialty" mods and are SLOWLY catching up. But I think their PRIME market is the general open bow runabout market.
- I have no need for cruise control outside of those speed ranges and I'll guess that 90% of owners are similar
- It locks into a set speed, and you can adjust it as you drive if you want
- Ballast only enters the equation IF you are using ballast....which makes sense. IE--if you haven't loaded any, it effectively ignores it.
- I thought someone made a comparison to cars.....
Makes one wonder why would Yamaha call those things "Drive Control" and "Cruise Assist", the manual does not list cruise control option.I guess this is the part I'm struggling with.....I use my drive control as cruise control. Press Drive control button, preset one (set to 27 mph), activate, throttle forward and sit back. Boat accelerates on its own to 27 mph exactly per GPS and I can press the up or down button to slow it or speed it up. Works like cruise control for me.
Probably because they feel that RPM based cruise assist is sufficient for that use case while the Drive control focuses more on water sports cruise speed accuracy. I still agree with your point that there is no reason to have them separate. They have the wonderful big knob on the connext control that they could use for a cruise control controller (both RPM and GPS based). In the meantime....use Drive control if you want GPS speed control and cruise assist if you want RPM based speed control. I had no idea it was limited to 40mph....I'm going to have to test that next time I'm out just for fun!Makes one wonder why would Yamaha call those things "Drive Control" and "Cruise Assist", the manual does not list cruise control option.
Maybe this will help:I don't want to hijack the thread but @Julian can you help me understand the connection between the ballast and Drive Control?
More like weather-proof, same like regular gauges I was told.@Ridesteady
Are the displays fully waterproof? I'm more interested in the larger one like @swatski has.
