anmut
- 212S
250 hours on my motors and I decided I was well overdue to pull the pumps and grease the nose cone bearings. I believe this is something that's supposed to be done every 100 hours. Took about two hours from start to finish and I went really slow trying to be methodical as possible. Some surprises and lessons along the way:
![IMG_1846.jpeg IMG_1846.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/224/224326-c9fde5ed87e12f381768ecae5f58571b.jpg?hash=ZPyehu2dIq)
![IMG_1852.jpeg IMG_1852.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/224/224332-97378f1afa9d36a4609152db5d4096dd.jpg?hash=5CvcPi-Uco)
![IMG_1853.jpeg IMG_1853.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/224/224333-46adb7688a2f93d08c870abd88ab9b19.jpg?hash=REAgFR-ROP)
Burning/melting on impellers:
![IMG_1849.jpeg IMG_1849.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/224/224329-d91e4ad72e23a21e66aa723fa18da474.jpg?hash=GwHBzrmUDm)
![IMG_1850.jpeg IMG_1850.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/224/224330-704e77203883d0ed3668ce36d152ca52.jpg?hash=Zrib-3Cszz)
![IMG_1851.jpeg IMG_1851.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/224/224331-76d3fb823ef2a37b8c98c69306a74d09.jpg?hash=AEMxTlVdCf)
Broken anode bracket
![IMG_1848.jpeg IMG_1848.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/224/224328-4d3e4cb89bd984723aca8f2f23708048.jpg?hash=6ey2piBsdo)
![IMG_1847.jpeg IMG_1847.jpeg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/224/224327-11e36486fdbd19e21571c275f984b4c6.jpg?hash=1qnFMQ_AKk)
- This was my first time ever pulling my pumps out and I'm glad I did it with a full array of tools available and not attempting it at a boat landing after sucking up a rope. The bolts for both pumps were really tight and I had to use an impact on two of them on the port pump.
- Both cones were about 1/3 full of grease. STBD pump cone had a few drops of water in it. I was happy to see that, even with 250 hours on the original grease, the bearings were still in fine shape.
- No chips were found on my impellers but it appears I have some (or at least what I believe to be) burn on the bow side of the impellers. I **think** this is from surfing with a ton of water weight and the impellers creating super heated water on the edges that it's actually melting the metal. It's interesting to note that I've never felt any performance degradation on either pump. Port pump had the burns on all three blade and STBD only on one. Either way, I'll be replacing them at the end of the season.
- I found the easiest way to reline the pump splines back into the engine was to hold the pump assembly with my left hand and turn the impeller (while reaching around the back) and slightly turn the impeller until I could feel it line up, then slightly pushing the shaft into the splines to get it to set.
- I FOUND THE RATTLE in my pumps too - the damn anode bracket was broken my STBD pump - that's been driving me nuts for a long time, I can't believe I never noticed it before. If you have a rattle in your pumps at low speed, check your brackets. @Cobra Jet Steering LLC I believe these offset brackets are from your kit - how much are replacements?
- Parts I used for my 2020 with 1.8l:
- Epnoc Jet Pump Grease for nose cones (two pack)
- Yamaha Molybdenum Disulfide Grease for the shaft splines
- Yamaha O-Rings for nose cone
