meaningreen
Those things are def not worth $100k. I'd rather have a jeep wrangler with the 392 for that kind of money.Out Truck shopping and came across one of those $100K Bronco's. It was a First Edition and nice, but not $100K nice.
No kidding...Coldest morning dog walk in a few year’s.
Good day to keep the animals inside, put another log on the fire and
read and watch videos. Then take a quiz...studying to get my OUPV 6-pack captain's license.
Edit:
I need to do something constructive while inside this Winter.
No kidding...
We only got down to 2-3deg but it was enough...lol.
How to find poorly insulated pipes in your home?
Wait for a 3deg cold snap.
Call a plumber.
Of course - being me, it'll always happen over a holiday weekend, lol.
No kidding...
Call a plumber.
Sadly, I'm on the hook for a couple grand I figured, as this was a boiler line for heating - half of my house has floorboards, so the whole system needed to be drained, twice (there were three cracks spaced few feet apart, we only found two - at first..lol). It was fun. He ended up spending a good part of Lord's Day with us. That's gonna hurt, I don;t even want to look at that bill when we get it!I have seen my share of split copper due to freezing. It is common for water lines run along the boxer, the 2" x 10" boards that seal off the floor joists on the outside of the house, to freeze. Mine were in an insulated space in the ceiling of the garage run along that boxer and they froze on a -20° night. Once fixed, I left the 5/8" sheetrock off along the pipe run to allow heat from the garage to keep it above freezing. Patched more copper in the barns than I can remember and they are heat traced. Something always happens. I try to use PEX now, it is more forgiving in a freeze up.
We have had to do it once and I swore I would never do it again...Do not call a plumber on a holiday weekend. Our call once on a Thanksgiving Thursday for a clogged kitchen sink drain that my snake could not reach was $300. He was there a 1/2 hour. I bought a better snake after that.
Oh, well, at least he's a nice guy. I'm having him replace the whole system with a tankless heating and hot water, once it gets warm.
Similar thing happened to us while on a cruise. Came home to the whole main level needing gutted due to broken water line. The only good part was we had friends checking in on the house while we were gone & they shut the water off, called a cleanup crew in and most of the work was done when we got home. Cabinets were out, flooring was out, drywall from floor to 2' up was out, insulation was out and there were so many industrial fans and dehumidifiers going it was just crazy. It gave me a chance to install new windows, rewire and reinsulate with better insulation on the whole main level.We were on vacation once on a cruise in Febuary 1995. We were in a different house then that we built in 1990 on a piece of land I owned after moving back from Florida. The plumber installed the S/R copper heating lines to the second floor in the exterior wall in the kitchen, behind the cabinets. Before we left we did not adjust the T stat to keep heated water moving to the second floor. Only the first floor heating was working. Well that upstairs loop froze in that exterior wall behind the cabinets. The weather then warmed, we were still gone, and the frozen line thawed and dumped 8" of water on the basement floor by the time we got home. A 44'x 24' area. I had to tear apart the outside of the house, in Febuary, to get to the piping and fix it.
Good info, thank you.We were on vacation once on a cruise in Febuary 1995. We were in a different house then that we built in 1990 on a piece of land I owned after moving back from Florida. The plumber installed the S/R copper heating lines to the second floor in the exterior wall in the kitchen, behind the cabinets. Before we left we did not adjust the T stat to keep heated water moving to the second floor. Only the first floor heating was working. Well that upstairs loop froze in that exterior wall behind the cabinets. The weather then warmed, we were still gone, and the frozen line thawed and dumped 8" of water on the basement floor by the time we got home. A 44'x 24' area. I had to tear apart the outside of the house, in Febuary, to get to the piping and fix it.
Edit: I really do like the 151kbtu Bosch Greenstar condensing combi boiler that we had installed in this house in November. Much more efficient than our 20yo HB Smith boiler. The Bosch is very quiet and works very nicely plumbed to a heat exchanger fed from the outdoor wood boiler. I really like the adjustability of the aquastat that allows you to turn the temperature down so you don't need to heat water to 180°'s when you are not heating during Summer. I can adjust temp to 120° or below for domestic hot water needs during warmer months. The aquastat will also shut the gas burner off if you need to.
It has separate controls for heating and domestic on demand hot water.
That is the temp of the boiler at idle. No T stats are calling for heat and circulators are not actively pulling heat from the heat exchanger from the outdoor boiler.
I may need to stick with whatever my guy is selling though, if we go that route. He only deals with one or two brands, one is Navien which is not the best but okay, offers some units with good track record.
I want something that plugs into a regular 110V outlet which is hard to find as most units in those sizes need to be hard wired. I could run it off of a small generator if need be, hit by a hurricane, or something.
Our water heater popped while we were on vacation in October. We had the Navien brand tankless installed, and so far it has run flawlessly. It takes it a little longer to warm up than our old tank, but having endless hot water has been great! The dishwasher can be running and I still get a nice long hot shower. I’m considering having the recirculation valve added, so the hot water comes out instantly.Good info, thank you.
