robert843
- Myrtle Beach, SC
So I have installed several amps and subs over the years in cars and boats but I have never installed multiple amps so I have a few questions. First I plan to run a power block to a location closer to the helm to assist with amp install and other items I plan to add which would be a gps and a shower kit. When doing this do you install the inline fuse to the size of the capabilities of the bus box so for example it it has a 100 amp max you put a 100 amp inline fuse in or do you only run to the capabilities of the devices you have added so even if the bus box has 100 amp peak but you only have 80 amps of items on it do you use the 100 amp fuse or the 80 amp? One of my amps has two fuses on it a 35 amp and a 40 amp does this amp need to be connected to a 75 amp fuse at the bus box or just a 40 amp since the largest fuse is 40? Basics tells me 40 amp as 75 amps would blow the first fuse but I'm really not sure. Also ant recommendations on a power block as most I see are to low of amps for what I plan as it looks like I will need a minimum of two connections that can handle 40 amps each just for the amps and most I see cap at 30 amps? Lastly can I connect both amps remote grounds to the head units one remote ground wire or is that asking to much of it. I willl tag a few who may know my answers @Earmark Marine @David Analog @Andy S @Julian @Bruce @Drift Away @swatski
