Nightmare
- Southern California
- Limited S
You'll likely get a billion answers to that question, but if it were me, I'd start with fine Scotchbrite first, with even motion/passes.The prop has no nicks or anything, but there is some rust on the blades. What should I use to clean off the rust?
I only used some vinegar and a toothbrush for most of the parts. I scrubbed the shaft with a non-scratch kitchen sponge.That is just stainless steel bleeding take a small hand held stainless steel brush and it will disappear quickly.
Robbie, if there's no star washer, there's really nothing for the bolts/nuts to grab onto, so that's just going to be the issue with the fasteners. Even if you added a star washer, there's a chance that you'd start to abrade the fiberglass when tightening them down.I installed my 2.0 Lateral Thrusters, and updated the current Thrust Vectors. Easy install. Can't wait to try them out. I also installed the access port riser (not pictured) Not happy with the way it bolts down. The nuts are tight, but the screws still spin. If I tighten them anymore they'll snap. Not sure why this is happening. I already sealed it, so after it cures, I'm changing the hardware out one at a time.
What was involved in updating your Thrust Vecotrs? Did you swap your older version with the newer version, or what exactly was updated?I installed my 2.0 Lateral Thrusters, and updated the current Thrust Vectors. Easy install. Can't wait to try them out. I also installed the access port riser (not pictured) Not happy with the way it bolts down. The nuts are tight, but the screws still spin. If I tighten them anymore they'll snap. Not sure why this is happening. I already sealed it, so after it cures, I'm changing the hardware out one at a time.
I like it... Im thinking about moving my home brew magma mount from the wake tower to the stern... and that pesky beer always gets in the way of progressI balanced this grill that I got for Christmas on my table leg. I had some kind of plan but started drinking beer & it’s still just balancing there.
I’m going to try to shortcut this whole mount thing and try what the guy in the link below did with a reasonably cheap rod holder. We’ll see how it works. I never noticed how this factory table leg has a goofy taper at the end.
I ended up just buying the magma locking mount and now trying to glue some rubber to it to make it fit the table leg. It’s expensive but it’s a beefier and better designed piece than I could tell from pictures online.I like it... Im thinking about moving my home brew magma mount from the wake tower to the stern... and that pesky beer always gets in the way of progress
That's what I figured. I'm going to change the screws from allens to phillips, and add flat washers on the bottom. After I thought about it, there is no way for them to cinch. As long as I have a good seal it's all good. I'm OCD to a fault. Thank youRobbie, if there's no star washer, there's really nothing for the bolts/nuts to grab onto, so that's just going to be the issue with the fasteners. Even if you added a star washer, there's a chance that you'd start to abrade the fiberglass when tightening them down.
I DIY'd my own, so I just drilled out the holes to the next larger size, bought the appropriate screws, and went that route. If one of the screws eventually strips out, I'll go with a nut/bolt combo. You MIGHT be able to just add a flat washer and suck it tight, but you'll never be able to get it to grab to the deck enough to guarantee that it won't spin.
When you order the 2.0 Lateral Thrusters, you get new designed fins so that all 4 have the new cutouts. I'm thinking about adding an additional tie rod now since there is clearance. I hope I like the thrusters, I drilled my FN nozzles. Thoughts on the additional tie rod? Should take the strain off the starboard cable.What was involved in updating your Thrust Vecotrs? Did you swap your older version with the newer version, or what exactly was updated?
I can see the usefulness of the extra tie rod. I'll be interested in your experience with the lateral thrusters. I don't have much need for them with my typical boating, except for one bar. Current is coming around a corner, and it's one of the faster-moving spots on the river. Thankfully, they offer shite service and are overpriced, so we rarely stop in.When you order the 2.0 Lateral Thrusters, you get new designed fins so that all 4 have the new cutouts. I'm thinking about adding an additional tie rod now since there is clearance. I hope I like the thrusters, I drilled my FN nozzles. Thoughts on the additional tie rod? Should take the strain off the starboard cable.
