DIY Steering Cable Luber
pbarton13
275SE
I have a 2021 275SE and the port side steering is tight. Was tight at the beginning of last season as well, but freed up after external spays of CRC and moving the wheel. The shop is saying a month to get the boat in and replace the cables. For the newer, sealed (at helm) cables, has anyone had luck performing this fix from the transom side. Thanks in advance.
Thermobrett
Lithia, Florida
SX195
Just note this is part of the "routine" Yamaha preventative maint. Im currently fighting with my dealer on a frozen steering cable. I have a running thread under the 190 model section.
AZMark
Phoenix, AZ
Some have, some haven’t.
Mine and @HangOutdoors cables were totally screwed and lubing under pressure from the transom side did not work on one side for each of us.
pbarton13
275SE
Thanks. Steering is just tight, so I’ll give it a shot. The boat stays on a lift, I’m surprised to be having this issue. Taking a look at it, replacing the cables looks pretty straight forward as maybe a plan b.
AZMark
Phoenix, AZ
Good luck.
Replacing is not a small job but it’s not too bad. It took me several months to get a cable last year.
2015 SX210
OMG, just found this thread after centering my steering wheel. Turning to the right was a two hand job. Just bought the material at Menards for $30 and spent about an hour from start to finish. The steering wheel turns like a new boat now both directions!!!
Thermobrett
Lithia, Florida
SX195
How was pumping the 90w oil, any difficulties due to thickness? I bought the Star Brite 90w gear oil and I am plan on doing this Sunday after we get back from using the boat. This is the fitting I made yesterday for the 3/8” ID hose. I have a new steering cable in my boat and figure a once a month lubrication isn’t a bad idea. Might be a little over kill, but beats the downtime waiting for a new cable again. I wish Yamaha did a better job designing a way to lubricate the cable from the helm and push water out opposed to pushing water in further. Let gravity work in our favor.
drewkaree
West Allis & Fremont, WI
2015 SX210
No issues at all, it actually went really fast. Probably pumped in 2-3oz at most in each cable.
AZMark
Phoenix, AZ
It seems like if your cables aren’t already screwed any type of oil will go in just fine.
If they are screwed it doesn’t matter how thin of a fluid you use, it won’t go in.
Thermobrett
Lithia, Florida
SX195
Agreed, I couldn't push water into my old cable if I tried.
lazergeek
South Florida
Agreed I cant even get penetrating oil in my starboard side. Im chancing a few more trips out before I order since everyone is out of stock anyway.
AZMark
Phoenix, AZ
I tried same thing.
I’d get your order in so you’re in line if you can spare the cash. Mine took 6 mos or something. I don’t think they’ll just suddenly have extra stock at places anytime soon. These cables seem to be a common problem.
Thermobrett
Lithia, Florida
SX195
I was able to warranty mine out from the manufacture and replaced it myself. The dealer said they have had boats on the lot for replacement cables since November 2021 with no ETA. Same went for mine, but I did my own leg work from help on the forum and am back is business.
AZMark
Phoenix, AZ
You got lucky. My boat was a little too old and my extended warranty declined it.
Hopefully @lazergeek will have better luck.
lazergeek
South Florida
Partzilla had stock a month ago but I was dealing with getting my broken spark plug fixed at that time, now they are saying 60 days eta for the part. Dealer says its a wear item so warranty wont cover since im over a year since delivery.
Thermobrett
Lithia, Florida
SX195
That’s not true. Call Yamaha in Tennessee. It’s a parts and workmanship issue for components under the 5yr warranty from Yamaha, I called and questioned it when the dealer told me my steering cable wouldn’t be covered under warranty. Yamaha was very quick to tell me otherwise.
