captainhook
- Southern Maryland
- Limited
Perfect weekend weather for the boat...
They should be able to send you pics of the impeller. Surprised they'd say it was unrecoverable....they can usually be reconditioned.So i called, they said that the impeller and pump housing is locked up, and both need to be replaced...
Is this accurate statement ?
Also, how much difference is it going to make with the impeller being changed out compared to the right one ?
How much should something like this cost ? I want to make sure I am not getting ripped off
Thanks yall
Tracking....
I was debating on doing that @Bruce I am not against doing both, but I want to use it for the summer "sigh"
I would choose and order aftermarket housings and factory impellers and install them myself. You can swap them out in a day.
I just got a quote update... to do both motors pull and install from sbt impellers and housing its gonna be $1200 which includes labor and material
They plan on using SBT imepeller and pump housing...
I figured you would say thatLOL.....
Damnit @Bruce... Problem is I am on travel for the next 3.5 weeks :|
It is just a matter of pulling the two pumps at around 15 minutes each, taking them to a jet ski shop to swap the impellers and housings then 15 minutes per side to reassemble. The labor for swamping the impellers should not be more than a few hundred. Swapping pump housings might take 30 seconds.
I do know the impellers they were going to replace it with were the stock impeller pitch, and the sbt jet pump housing.
I talked to SBT today. They do not have impellers in the standard pitch. They have one of the impellers but do not manufacture the other.
Give bayside a call and get second opinion from EricHmm..... so wtf... LOL
He may be able to debunk or give you questions to ask the shop that has quoted you.Not a bad idea.... problem is he isnt remotely local at all which sucks :\
