sunbyrned
- Louisville, KY
- 242 Limited S E-Series
I just pour water from a water bottle on mine and they slip right in.
Been there myself. You don’t know until they are out how hard they can be to get back in. I jammed mine back in the same way you did. But I agree with @Julian, they are too far gone. Save yourself more trouble and order the rebuild “kits” (they are actually just parts and the only thing you really need are the rubber o-rings).Well when your out on the lake and a stick stuck in jet. 2 of us tried to get them them in for a half hour. Next hammer comes out. I have them out drying and got some silicone to lube them. I’ll try that.
@sunbyrned ......and you really expect us to believe that's water in that bottle?I just pour water from a water bottle on mine and they slip right in.
There fortunately are a couple of lubricants that can fix swollen plugs.No amount of lubrication now will fix swollen plugs. As DRAT says below, order the rebuild kits (SUPER EASY) and just rebuild them. If it takes you longer than 20 minutes to do it, its because you stopped for a beer between unscrewing the two plugs! Trust me....you will be delighted with how they work after you replace the bottom halfs (that is all it involves...6-8 screws on each plug)
I know the OP has an older boat, when did they change the cleanout plug design? I'm REALLY puzzled at the guys with 2020's that are having problems - I've left mine in since I got the boat, no problems with them sticking whatsoever, and I'm hard pressed to figure out how the new plugs are sticking at only 4 weeks. The new design seems, to me, to have solved whatever issues the old plug designs had.
Is it possible that I just have cleanout plugs that are bad (but work perfectly fine and won't give me problems due to them being "bad")?
No idea if either could be the case, but in my situation, I know for certain it isn't #1. My lake has zero clarity and a metric ton of crap in it. I've left the boat in the water 3 times last year for a total of a little less than a month, and no swelling.I have 2 ideas about why this could be.
1. The lake. It seems nuts, but it happened to me. Over the last couple of years, i’ve Wet slipped in2 different lakes. The lake with less clarity and lots more organic matter swells the plugs up within days, and requires lubing the plugs about once a month to get them safely removable and replaceable. The lake with more clarity and less organic matter does not even require lube to keep the plug working.
2. I believe the screw in plugs may demand tighter tolerances than the push button plugs. The push button plugs work kind of like an expanding wall anchor, the screw in plugs are more like a finely Threaded screw. The screw would certainly be less tolerant of debris in the threads and much more sensitive to the amount of torque transferred to the head.
Mine seemed fine all last year anytime I took them out. This year they seem to stick more easily. I’ve been spraying some silicon spray on them..seems to work well.No idea if either could be the case, but in my situation, I know for certain it isn't #1. My lake has zero clarity and a metric ton of crap in it. I've left the boat in the water 3 times last year for a total of a little less than a month, and no swelling.
I'm wondering if I should even risk taking a look at them to see how they work - don't fix what ain't broke, and all that stuff.
Problem with me is, I almost feel like I GOTTA take a look to head off potential future problems. Mebbe my apathetic side will take over before I make it back to the boat. Fingers crossed!
I think that perhaps the members having issues with the screw in plugs may be salt water boaters.No idea if either could be the case, but in my situation, I know for certain it isn't #1. My lake has zero clarity and a metric ton of crap in it. I've left the boat in the water 3 times last year for a total of a little less than a month, and no swelling.
@Julian ......yes, common sense - that is (IMO) absolutely the over-riding answer.I think that perhaps the members having issues with the screw in plugs may be salt water boaters.
When I first saw these plugs and was demonstrated them by the Yamaha design team, I asked them if they wouldn't be susceptible to getting stuck just like the old ones. They said they'd tested them a ton and "no issues ". I pressed about salt water use, and they hedged a little there....basically saying...well if you dont maintain them and clean them, of course they'll stick eventually. Which is obvious.
Bottom line...they are easy to forget about and something that many members just leave and never touch. That results in stuck plugs. Members who maintain them, by removing, cleaning and keeping them dry dont have issues with them sticking.
So if I'm understanding correctly, the new plugs (at least 2019 or newer) MIGHT be a problem in salt water, I'm guessing perhaps due to galvanic corrosion or just regular old "salt water messes with everything". I'll keep an eye on mine, being in fresh water, or tinker around to see how these things are designed, break it, cost myself some money, time, and frustration, and report back if/when things go haywireI think that perhaps the members having issues with the screw in plugs may be salt water boaters.
