1BadTundra
 - 212X
I made mine out of 2 cutting boards as well.
Anyone have any tips/tricks to getting the large bilge access tray off? I've taken the clamps off the ports and all the screws out but it seems that it's glued or something to the ports themselves. I don't want to pull too hard because I feel like I'll pull the port right off the bottom connection.
Yeah it’s definitely free around the edges where the screws were. It’s the actual spot where they sit in the ports that won’t move. I’ll try with a thin scraper and see if I can free it.There are the hose clamps for the cleanout tubes and the drain, but they are also silicone in the hoses too, I had to use a screwdriver around the hoses to get them out. The tray is also silicon in too. The tray can leak even with silicone. I used neoprene weatherstripping on mine since I seem to get in there frequently.
I stuck my hand down the cleanout port with a flat head screwdriver and worked my way around the top inside edge with that to break it loose.Yeah it’s definitely free around the edges where the screws were. It’s the actual spot where they sit in the ports that won’t move. I’ll try with a thin scraper and see if I can free it.
The rubber tubes are supposed to be adhered with silicone as well as the tray itself. If you have run something under your cleanout tray to break the tray seal, the silicone on the tubes should be the only thing left holding it on, since you undid the hose clamps. Remember to re-silicone them when installing again.8
It's an easy install.Link to the riser ?
The cover gives you access down into the bilge area. It is supposed to be removable. Yamaha did a HORRIBLE job at sealing this area up on my 2020 AR240. I was getting gallons of water in my bilge every outing. Water was not splashing over the deck on deceleration. If I went hard reverse, I could get a tiny amount pushing up from the drain, not enough to make any difference. All the water was coming past the clean out ports. How do I know this? I stuck a GoPro video in there and recorded it. Youtube link below.
I would remove the entire cover as seen in the photo. Clean up the area, and reseal. I also added the access port riser from Jetboatpilot. I filled the area with water and plugged the drain with my finger and can confirm it is now water tight up to the top of the access port.
Yes. Add some type of silicone sealant. I used 4200. When it dries, plug the overboard drain and fill with water to check for leaks.I have this same leaking issue on my ‘22 AR210. When you re-install the cover, do you add silicone to seal between the clean-out ports and cover, too? I think I’ll also add the riser while I’m add it.
I have this same leaking issue on my ‘22 AR210. When you re-install the cover, do you add silicone to seal between the clean-out ports and cover, too? I think I’ll also add the riser while I’m at it.
