Is there debris stuck in there?i have shut the batteries down multiple times. i tried to switch to manual but the buckets are not moving. am i missing something?
the five times didn’t work. under the helm is a box with red levers for electronic operation and manual operation. have switched to manual and tries to move buckets by hand but no luck.no. odeTypically the way to clear codes is to;
shut off batteries
turn on batteries
start engines
shut off engines
shut off batteries
Repeat that five times.
no codes. have been feeling for debris and can’t feel anythingIs there debris stuck in there?
Do you have any fault codes?
When the red levers are switched it should release the cable from the shift gate and they should move up and down if you grab them. Try shaking them left and right to see if any pebbles are lodged.under the helm is a box with red levers for electronic operation and manual operation. have switched to manual and tries to move buckets by hand but no luck.no. ode
i have tried with me hands to lift the gates with the red levers in manual operation and no luck.When the red levers are switched it should release the cable from the shift gate and they should move up and down if you grab them. Try shaking them left and right to see if any pebbles are lodged.
Did you recently hit reverse in shallow water?
Maybe the red lever is not shifted all the wayi have tried with me hands to lift the gates with the red levers in manual operation and no luck.
what happened was i was going in reverse and ns my foot hit the power switch and shut the boat off while i was in reverse . pretty sure that’s the whole problem. i just can get it to reset.
The picture you posted shows them in the "manual position"yes wet slipped. i can’t get the levers under the covers to move to release….
