Valerie
- Orange City, Florida
- Other
- PWC
All the towing policies I've seen will cover towing in the area we will be in. Losing a boat entirely would be highly unlikely.
At this point I follow the directions of the Coast Guard plain and simple. All I'm saying is that this scenario is unlikley (not impossible). If your boat is going to swamp, it is most likely going to happen at the inlet where the water will be roughest. Can in happen out in open water after you've gone 25 miles...Sure it can. But as with planes....the probabilities show that takeoff is the highest risk time, followed by landing.If your boat is disabled 25 miles from Florida you are two hours plus from a tow. The closer you get to Bimini the worse that situation gets. The other boats in our group are not large enough to tow your boat and it likely would be unsafe for them to wait two hours with you. So you send your family and friends ahead on another boat. Now you have the final decision to make, do you go with your friends and family or do you stay on your boat drifting at 4 mph toward Greenland. Is your boat or your life more valuable to you?
Are you sure about this? Most insurers will not touch anything once you are in international waters, unless you have a specific waver. Otherwise, pretty much the only way to get coverage would be if the boat sinks and you lie about where it happened...All the towing policies I've seen will cover towing in the area we will be in.
Sure. IF you can talk to them, which becomes tricky once you are out of VHF radio range, and certainly past 30 miles offshore.At this point I follow the directions of the Coast Guard plain and simple.
Not only Sea
Yamahas can sink too! Quoting the obvious, or just about any watercraft that gets capsized and totally swamped. I was the happy owner, at least for some years, of Yamaha GP 1200 I sank twice riding hurricanes surf on NC coast. Definitely a very significant emotional event! But I was only about a mile from shore, and was able to do the olimpic swim behind it as very strong swells pushed it to shore. Loose handle bars, and few scratches, but a bottle of starting fluid direct into pistons and carbs and new set of plugs was riding it home about an hour after I got it to shore. Whole different ball game out at sea, and an experience I rather pass on!
I'm not sure where you are buying that distilled water but you may want to get yer money backprepped for the trip!
When I had progressive/USAA to go along with the 75 miles there was language that said only in the USA territorial waters. Even though Bimini is only 60 miles away it is outside of USA waters and not covered. I would read the language yourself and make sure you are comfortable with the coverage.I am covered up to 75 miles off the coast. I am with Progressive/USAA. I called and spoke to them Friday.
I went with AllState and at the time they covered Bimini. I'm now with Traveler's but they don't cover outside the US territorial waters but I'm ok with that.Should I look at a different company since Progressive won't cover? Anyone have any suggestions?
