The official "What did you do to your jet boat today" thread.
I hadn’t considered it. The hardest part was making the templates for a nice fit and finish and I image the anchor locker on a 22’ is different than a 25’. I can send you some measurements if you’d to compare.
Please do.
Ramp-n-Clamp installed! I’ll give feedback on function on Thursday or Friday when I’m able to get to the water again. I went with the long arm version, so I can just pull a rope to launch and my wife can go park the truck without having to get out on the ramp. But just my first impression in the driveway is that this thing is gonna be a game changer at the ramp. Just tapping the brakes to slide the boat forward on the trailer and it slid right into the V and locked into place. Tightened the winch strap and done. And it’s made of the same material at the Stoltz bow rollers, so it shouldn’t mark up the hull at all either.
Small stuff but a headache.
Found a bunch of water after rain in Galley Box Compartment. Usually, would store stuff that I do not want to get wet.
So, found out that drain hose for the cup holders secured with some flimsy ties and was easy to take off.
Putting new zip ties did not improve that compartment was still collecting water. Found out that cups holder was cracked at the bottom.
Patrzilla gave me this part number F2J-U5633-00-00 on sale for $12.06.
But when you click on it it says does not fit the boat?!? Doubt it.
So, decided to take the broken cup holder off to see if I can find part number there.
For those who are puzzled how to take drink holder off - you need to twist silver ring and take it off to reveal screws.
Found this part number listed 81422-B/SS-SCR-PK2-SR that took me to ITC Manufacturers site where you can get pack of 2 for $16.99.
Got some hose clamps from hardware. Now verifying if I solved the problem.
Biggest pain in the a$$ is to tighten hose clamps with one hand.
For stuff that's hard to access like that, I will sometimes use butterfly band clamps. Not sure if the nipple gives enough room to tighten them down, but may be another option
View attachment 236497View attachment 236498View attachment 236499
I got to use the Ramp-n-Clamp for the first time today. Had to go deeper than normal to float the boat off the trailer to relieve the pressure on the latch before it would release, but it was only slightly deeper than a normal launch, so no big deal. Pulled the rope and the boat floated back away from the trailer nicely.
When retrieving/loading back on the trailer, I had the wife back slightly deeper than normal again. I used the X-drive paddles to slowly approach and center up on the trailer. When the bow hit the pad on the Ramp-n-Clamp I heard the latch click around the eye. I was a little apprehensive to give my wife the thumbs up to pull away from the ramp, so I checked first to make sure it was latched. It worked exactly like it should. Next time it’ll be just a click and a thumbs up and we’re off the ramp and out of the way.
Very pleased with it. And highly recommend it.
Always good to give something like that a visual… especially since you put the slip and slide on the bunks?
Headed out to the lake today with a plan to troubleshoot a problem I’m having with my steering… barely pulled away from the dock when I received a hot engine warning. Confirmed it was in the starboard side, shut it down and continued on one engine to a safer location and dropped anchor. I pulled the plug and cleared out the weeds, but had to pull out a knife to cut off whatever was wrapped around the shaft. Of course I cut myself and banged up two knuckles, so now the cleanout tray looked like somebody just gutted a fish. Determined not to let this ruin my day, I persevered until I eventually pulled out a part of someone’s compression sock. Feeling around, I knew I couldn't get the rest of it out, so I pulled anchor, limped back to the dock and went home.
I ended having to pull the pump to remove the rest of the sock. Thankfully, I had already pulled the port side pump and had the sealants I needed to put back together. So with only 6 hrs. on this boat, I’ve already had to pull both pumps and had to replace the trailer jack. One would ask if I’ve ever driven a damn boat before! Tomorrow's a new day and we're going to try again!
❤️ the perseverance !
*saving this for possible meetup ammo 😜
How was the next day?
Well… I didn’t break anything, but didn’t resolve any issues we’re having either. Went out again on Sunday with the family. Nice day, but the Canadian smoke was pretty bad. Dropped anchor for a few hrs before heading back in. Developed severe cavitation in the starboard engine as we were pulling up to the dock. Tied off, checked the clean out and found what must have been a full spool of fishing line wrapped around the impeller. Loaded up and went home… hoping to clean that out tomorrow! At this point, we’ve nicknamed the boat PITA…
Have you considered boating somewhere other than what seems like a landfill?
Did you resolve the steering issue ?
Not yet… the issue is only a problem when launching and recovering, but as long as I move really slow, stay mindful of when shifting in and out of neutral and avoid sudden changes, I’m adapting. The dealer is getting anxious to find a solution as apparently others are having issues too. Hopefully Friday. 🤞 In the meantime, the hard reset seems to have fixed the issues with the depth finder, highest speed and average speed.
First oil change of the season at 81.5 hours…prepping for my trip to WI and all things willing hope to burn a lot of fuel when I’m there to finish my tour of Poygan, Winnecone, Winnebago and hopefully more than one day on Lake Michigan.
I scrolled back a few pages and couldn’t find your post about the steering issue… is this the issue with the steering becoming opposite at low speed ?
Yes, it’s called neutral steering assist. When shifting into neutral, the steering response is reversed. If I turn the wheel right, the front swings to the left and vice versa. When in forward or reverse, the boat reacts as expected. So it can get a little intense when you’re shifting in and of out of neutral. At first I thought the issue was exclusive to the Drive system, but I learned it behaves the same way in normal mode too, it’s just more noticeable during low speed maneuvers.
Okay…seems odd. Perhaps try centering the wheel and split the throttles ? Unless it’s super windy that’s the way I drive my boat around the dock or when loading it on the trailer.
