JetBoatNewb07
- Other
- 252SD
Guidance question gang...have a '23 252SD, while I'm hoping to avoid any issues that put me down on the water, I realize it does happen. I haven't found anything that walks through the steps of how to properly have the boat towed on the water to avoid damaging the engine(s) that are down. I have purchased the pinch clamps that others have suggested but I'm unsure which line needs to be pinched. I've also seen that you don't need to pinch any hoses closed as long as it's towed at barely above an idle. Can someone on the forum answer this for me or point in the direction of an adequate article? Thanks in advance!
