- Georgetown, IN
Well, took some time this afternoon and tried everything I could think of to increase the pressure in the system.
Pulled the line off the feed from the jet pump to prevent backflow out of the pump. That backflow is excessive IMO. I'm considering adding a tow valve just for flushing because of this.
That didn't reveal the leak.
Then I left that line blocked and started squeezing off the pisser line to increase pressure. Used a pair of vice grips to neck down that outlet. No dice, still no leak from anywhere obvious. There remains only a few places that it can be leaking from.
Went to the hardware store and got a mechanics mirror and some ear muffs. Going to take it out on Sunday and just give it a try. I can't simulate enough load in the driveway to find it.
I did notice that the water comes out of the boat in 3 places while on the hose. Exhaust, pisser, and another fitting on the transom. I traced this transom fitting back to plastic fitting on the rear of the cylinder head. It had SIGNIFICANTLY hotter water coming from it than from the exhaust. The exhaust water was relatively cool at idle, but the other water was scalding hot........the water in the boat two weeks ago was scalding hot as well. I'm suspecting a leak from downstream in the cooling system at this point and NOT the exhaust.
Oh yea.....bilge pump is dead. Have a new one to put in before we go out again, that way at least I can get the water back out of the boat this time.
More details as I figure them out.
