- Raleigh, NC 27614
- 242X E-Series
[HASH=645]#YDS[/HASH]
Ever wonder what your engine hours are, how to read them, if your engine threw errors? Well first of all you will need some software (YDS 1.3) and a Cable (Ebay is a good source). Once you have that, here is the process from start to finish of what you need to do:
There are lots of other things this software can do, but that is for another day. Here is what it read as an example for my engine hours:
Engine speed Time[h]
- 2000 r/min 30.67
2000 - 4000 r/min 53.97
4000 - 6000 r/min 7.4
6000 - 8000 r/min 27.82
8000 - 10000 r/min 11.2
10000 - 12000 r/min 0.99
Total hours of operation 132
Attached is a copy of the file you can create and save from the software.
- Install the software 1.33 for 2012 or before models. It looks as if you need YDIS 2.13 for 2013 and newer boats. At the moment it appears there is no available software to access these boats. (on some kits sold on EBAY, it has 2 disks...one for the YDS, and one for the cable driver--install BOTH)
- Update the DB on the software (launch the SW and press F1)
- Make sure the cable is on COM Port 1.
- Locate your connection point on the engine. If you have a 2006 or less, it will be behind the cover plate in the rear starboard storage locker (yeah who would have thunk!). On 2007+ 230's it is behind the plate on the starboard side of the engine compartment. On 210s, it is tucked into the wiring harness over the top of the port engine. It will have one red wire on one side of the plug and 3 or 4 wires on the side you will plug into. On the 2015s the YDIS couplers are located in the driver's helm compartment. The YDIS couplers are identified by "DIAGP" tag (port engine) or "DIAGS" tag (starboard engine) on the deck wire harness.
- Plug in the YDS cable to your engine.
- Start your engine (or just bump the starter enough to get a reading)
- Turn on the water to your engine (only if you start the engine)
- Plug in the USB plug into your computer
- One time only step--you should get a "New Hardware" message...if the disk is still in the drive, it will find the drivers. If it is not, then browse to C:\Program Files\YDS\Driver
- Launch the YDS software.
- Hit Enter it should says something about communicating to the ECM. If it says it failed to communicate to the ECM, then either your driver didn't install or you aren't plugged in the proper sequence, or your cable isn't assigned to com port 1.
- Hit enter and you should have a complete menu of items you can look at. For Engine hours click on "Data Logger" and then click on "Engine Operating Hours according to engine speed"
- If you wish to save the hours, click F2 to save the file (it saves as a .csv file or a "Comma Separated Value" file and an .xls file....in a nutshell....a file Excel can read, or most any data application like Notepad, wordpad etc.)
- If you want to check out and see if you have had any engine "errors", click on the "Diagnosis", and then on "Diagnosis Record".
- Shut off the water
- Turn off the engine
- 2000 r/min 30.67
