Ericd
- Illinois/Florida
- FSH Sport
Thought I would ask—just in case I might have to be towed sometime. Pictures show the back wall of the 210 FSH engine compartment.
I believe for each engine the main cooling intake line comes thru the wall below the red line, which appears to go the wash ports on the rear deck. These two line meet at a “y” junction and run to the engine. The main line is covered with a plastic ribbed protective cover — my guess it to reduce wear thru the wall.
If I am correct so far, my guess is I would pinch off the lower black hoses if I were being towed. What about the ribbed covering? Get it out of the way? Couldn’t tell if it was simply split and easily removed or not.
Also appears to be a difficult place to access to install valves on those hoses.
Appreciate your comments/help.
