biffdotorg
- Pelican Rapids, MN
- Limited S
I did my searches and all I am finding for issues with fumes is the blowers. So I will start a new discussion. I think I have it narrowed down, but your experiences are what I am here for.
I'm thinking my fuel cell breather or the check valve may have come disconnected. And to fix that, I honestly just need to put my head in the hull and connect it. But what I am curious about is if folks had a way to "check" the check valve or know of other causes of heavy raw fuel fumes in the cabin.
I have my boat on the lift now. And after pulling it out of storage, I topped the fuel tank off with 40 gallons of fresh fuel. After a day on the lift with the snap covers on, the smell of raw gas was strong. I immediately opened up the engine cover and started the blowers in case that may help as well. But also opened all the cabinets and under seat storage to try to find the source.
I looked for pooling fuel in the bilge, and only saw the standard cup of water or so. No fuel in from what I could tell and dipped my fingers in it and it only smelled clean. That made me feel good. So that ruled out the filler neck coming disconnected in my book. But next would be to pull the floor panel over the fuel cell and check connections at the pump and hull.
It's really strong, and I don't feel comfortable boating until I track it down. I suppose there is the chance that the filler came loose and fuel could have gotten in the hull, only to evaporate instead of drain. Again, visual inspection will have to happen.
Anyone else please share anything common I should check. If all looks sound, I may even try to rinse the inside of my hull from front to back with the drain plug pulled on the lift to be sure there is nothing spilled in there. But that would worry me more, making me wonder what may have leaked fuel in the hull.
The only thing petroleum based that would have been in the hull would have been oil from my oil changes in the fall. And a fair amount of that usually misses the dog potty pads I put down for when I swap out the filter. But can oil have that strong of a smell? maybe if it sat over the long winter? Maybe I need to do a simple green rinse of the engine bay, as I do not see anything and thought I did a good job.
Thanks as always.
Thanks as always.
