ScarabMike
- Green Cove Springs, FL
Scarab's line of jet boats have hit the market running, and Jetboaters.net has the latest reviews, information, and end user information on the net. If you are an owner, thinking about owning, or comparison shopping, check out these posts to do your research.
Scarab 165:
*MSRP: $22,653 - $28,067*Specs:
LOA 15′ 9″
DRAFT 12”
APPROX. DRY WEIGHT 1600 LB
BEAM 7′ 1”
MAXIMUM CAPACITY 850 LB
TRAILER WEIGHT 617 LB
FUEL CAPACITY 20 GAL
PERSONS CAPACITY 5
DEADRISE 21°
STORAGE LENGTH ON TRAILER 18’4″
BRIDGE CLEARANCE 3′
BRIDGE CLEARANCE WITH ARCH/TOWER 6’6″
*Reviews/Walkthrough:
Scarab 165 Walkthrough
Scarab 195:
*Specs:
LOA 18′ 10″
DRAFT 16”
APPROX. DRY WEIGHT 2600 LB
BEAM 8′ 0”
MAXIMUM CAPACITY 1400 LB
TRAILER WEIGHT 834 LB
FUEL CAPACITY 31 GAL
PERSONS CAPACITY 8
DEADRISE 20°
US Boat test: 195 HO Impulse Review
195 HO Walkthrough
*Multimedia
A Day with the Scarab 195 HO Impulse
Scarab 215:
*MSRP: $40.787 - $60,187*Specs:
LOA 21′ 0″
DRAFT 15”
APPROX. DRY WEIGHT 3100 LB
BEAM 8′ 4”
MAXIMUM CAPACITY 1800 LB
TRAILER WEIGHT 1095 LB
FUEL CAPACITY 41 GAL
PERSONS CAPACITY 10
Boat Test.com's 215 Review
215 HO Impulse Review
215 Review Jetboaters.net
*Multimedia:
Scarab 215 short video
Behind the Scenes with the 215
Scarab 255:
*Specs:
LOA 25′
BEAM 8’4″
FUEL CAPACITY 56 GAL
DRAFT 15″
MAXIMUM CAPACITY 2,100 LB
PERSONS CAPACITY 13
APPROX. DRY WEIGHT 3,800 LB
TRAILER WEIGHT 1,470 LB
DEADRISE 20°
Rotax 1503 engine:
*Specs N/A:
- 4-stroke
- 3 cylinder
- 12 valves
- Intelligent throttle control
(1503 NA ETC) - 1494cc
- liquid cooled/closed loop cooling circuit
- Dry Sump Lubrication
- EFI
- 4-stroke
- 3 cylinder
- 12 valves
- External Intercooler
- Mechanical driven supercharger
- 2 water cooling circuits (one closed water cooling circuit)
- 2 oil pumps with replaceable
paper oil filter, EFI
Scarab Boat Care and Maintenance:
*Scheduled/Regular Maintenance:
Engine Flush, and flush kit
Winter prep/Winterization
Rotax Wear Ring Replacement (159mm BRP Ring)
*Issues/Repair:
Center walkthrough window weather stripping repair
Scarab Brand Trailers:
*Care and Maintenance:*Modifications:
Trailer Jack Replacement
Trailer winch and bow roller replacement
*Issues/Repair:
Possible Rust Issues
Scarab Jet boat Modifications/Aftermarket:
Add a dual bank chargerAdd a second battery
Replace factory radio
Add underwater LEDs
Accessory/Option Reviews
Scarab accessory compilation/reviewsSea-Doo ClinX
*Learn how to Operate your Scarabhttps://jetboaters.net/threads/sea-doo-scarab-glastron-chaparral-how-to-clinx-series.5116/
