OCMD
- Ocean City MD
- SX
I've seen up to 90 psi/ Really?
Only your sidewalls will tell you the pressure. Be sure to inflate to max when cold.I've seen up to 90 psi/ Really?
This is the way.All the guys at big o and americas tire tell me to run the max pressure cold stated on the side wall of the tire unless the trailer says otherwise and your using the same size tire that came with the trailer.
This is what you need if towing long distance. Its great to know whats going on no matter what the pressure needs to be. Trailer tires heat up from the sun and the air pressure on the sunny side is always about 8 10 lbs more plus they just go up from friction. My max is 50 I fill to 45 when cold, stock tires from 2018 shore lander
tire pressure monitoring
We bought new wheels and tires, also replacing the spare. Going to put 2500 miles on them over the next 2 weeks.The stock Carlisle’s have a speed rating of 81, impressive really. But, my Carlisle’s got flat spots in them and were also out of round that never went away and vibrated like crazy…I could see the spare tire vibrating on the mount going down the highway.. Now with the Goodyear endurance they are as smooth as can be, spare doesn’t vibrate on the mount.
I still have the stock Carlisle spare though. Hopefully will never need that, going to try and wear some of the tread off of those Goodyears this summer!
