drewkaree
- West Allis & Fremont, WI
Couple things - when you mention that the holes are a little small, what is that in reference to, the cleanout tray itself, or the fiberglass decking underneath? Can you shoot me some pics? If it's the cleanout tray, I wouldn't worry in the least about it, but I'll await your response (and pics, hopefully) as to why. If it's the fiberglass decking, I'd really need to see a pic in order to reasonably comment. I don't know if I have any pics to match up to what you could show, but I can snap a few next weekend. I have a picture in my head as to what you might be referring to, but actual comparison and working through this via pics would be the best way to progress forward on this.Well all the parts came in and then I realize the machine screws are a little bigger than the holes drilled. That wouldn't normally be an issue, but some of them are really close to the edge and some have been filled & redrilled. This is making me cautious and thinking I should get a 3/16” sized screw. I should have been paying more attention to your post @drewkaree.
If anyone is interested in doing the same project with bigger hardware I have a fair amount. I might see if I can return some. The weld nuts I found on eBay, likely stuck with them.
I will mention this - I had a similar issue as you, I thought the holes were going to be too small, but I went ahead with it (and can show you pics of how it turned out), and in the end, all turned out perfectly fine. There are a few holes that I thought would be suspect, even after fixing/addressing them, but the gasket (which you have) is really the superstar in all of this, and the bolts and weld nuts are really nothing more than something to compress the gasket and hold it tight to the fiberglass decking. Screws COULD be used, but the reason I went with the bolts is so that I would have something that wouldn't strip out on me like at least a few screws seem to do for everyone. The combo of something solid to thread into (the weld nuts), and the little tab on the weld nuts is enough to keep everything together and solid, with no future worries of stripping out as well as a reasonably solid connection to compress the gasket.
I believe that If your machine screws are 1/4-20, that's the easy route to go, and the easiest to get any replacements in the future, if necessary.
I have two other things to share, once the final part hits my doorstep - I learned my lesson when I went to order my scupper drain tubing, and it seems to be sold out everywhere, unless I want to pay an arm and a leg. As it is, the part I've been waiting on has been delayed almost two weeks, and it's finally made it to my STATE yesterday, so it should be delivered tomorrow, hopefully, or at the latest, on Monday.
One thing I will mention is that I swapped out the cleanout tray drain fitting with the one shown in post #109, and I couldn't be more happy with that fitting. I'll shoot you a link via PM in case you want to put in an order, it really is noticeably different, and I swapped it out with the original stainless replacement fitting, and used that new old stainless fitting (does that make sense?) in place of the old plastic lower cleanout tray drain fitting. I know that sounds very confusing when reading it, but pics when I'm done will show what I did. Then end result is that I have stainless fittings on both ends of the cleanout tray drain hose.
Pics! I'll do my level best to help you work through this!
