Bluewater272
 - Medford, NJ
 - Tidewater
 - Other
If you want to run anti freeze, clamping off the intake to the pump will help get more of it into the water boxes - which is the ONLY place that traps water.
FWIW, water does sit somewhere in the cooling system, even when you rev/blow it out. I run antifreeze every year, and the first hose start of the spring it pisses pink for about 10 seconds (solid pink), before water starts diluting it and pushing it out. It's clearly not enough water to damage anything, but its still somewhere.
If you have a boat with ballast pumps or a shower pump, I'd spend time putting anti freeze in that well before I ever did it on the engine.
This is a must. Main reason why i even started running it through the motors, already have all the crap out to pump it into the shower, $10 worth of antifreeze for the motors is nothing.
